Anyone with BMR Kmember and A-Arms please help
When installing should I adjust the rod end's on both side to be the same? You know the vertical mount point. The only way to get my drivers side A-arm to fit with out sqaushing the bushing on the horizontal mount was to adjust the rod end close to all the way in. Also where did most of you get your car aligned at after the install?
Thanks for any help
Sean
Thanks for any help
Sean
Re: Anyone with BMR Kmember and A-Arms please help
I have a PA Racing setup, but I would imagine the basics are the same...
I set up everything equal on both sides to try and get the alignment as "neutral" as I could. Anything that was adjustable, I set up in as close to the middle setting as I could.
I have a friend that's a GM mechanic at a Caddy dealership, and had him do the alignment. He didn't have any issues with it at all.
