Drag Racing Tech
new best, but is there more.
Old 08-19-2002, 08:37 PM
Terry'sToy's Avatar
Default new best, but is there more.
On sunday I ran a 12.50 @ 108.46 with a 1.76 60'
The tires spun just a bit but not too much. It was really hot out also.
I was wondering what others have run with similiar mods.
Thanks
Old 08-20-2002, 07:52 PM
Terry'sToy's Avatar
Default Re: new best, but is there more.
ttt
Old 08-20-2002, 08:05 PM
NastyWS6's Avatar
Congrats on the New Best
Old 08-20-2002, 08:14 PM
Terry'sToy's Avatar
Thanks.
Does anybody know of any way to stop this thing from spinning. I have LCA's, relocation brackets and 26x10.5x15 ET Streets, and the front swaybar removed, and an airbag with 20lbs in it. The best 60' was 1.71
TIA
Old 08-20-2002, 08:18 PM
Terry'sToy's Avatar
Thanks
Now I was wondering if someone could help me with my traction problem. I have LCA's, relocation brackets, ET Streets, RR air bag@20psi, and front swaybar removed. It still spins.
TIA
Old 08-21-2002, 03:44 PM
sweetTA's Avatar
How's your burnout? Launch RPM on the converter?
For me (same converter/tire), I'll get the tires just slightly wet in the box, and pull forward to do my burnout. See smoke, count to ~7, let off breaks roll out till it sticks. Dry hop it once before staging, stage, and launch @ 2000-2200
Old 08-22-2002, 09:18 PM
Terry'sToy's Avatar
I usually do a pretty good burnout. second gear 5500 rpm for about 5 seconds. I don't do a dry hop though. launch rpm around 1500, but i've tried all rpms and nothing seems to change.
What are your 60's like?
Thanks.
Old 08-22-2002, 11:13 PM
sweetTA's Avatar
My 60's are pretty similar to yours. Best of 1.70, average 1.74-1.75...We ET pretty similar and have similar mods, but mine dead hooks..
How many passes/street miles do the tires have on them..?
Old 08-22-2002, 11:27 PM
Terry'sToy's Avatar
These set have about ten passes on them and about 70 street miles. I tend to leave them on cause i don't live all that far from the track.
I didn't have the spinning problem until the evil st3500 went in. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 08-23-2002, 07:15 PM
kent's Avatar
Front and rear Hal shocks could improve your sixty foot time with front Hal drag springs. I ran 1.63 stock with the Hals. Best time in stock was 12.43. You can easily beat my best on a good sixty and good weather. Also, consider good weight up front for better weight transfer. Good luck.
