26 x 11.5 x 15 ET Streets
Have you guys had good luck hooking with these? My current 26 x 10.5 x 15's don't really hook that well (but they sat for about 8 months while the car was down)...so I am looking for another DOT approved solution.
Thanks,
Scott
Thanks,
Scott
Re: 26 x 11.5 x 15 ET Streets
I have the 26x11.5x15 on Conv Pro 15x10. They have their moments. I did drop my 60's from 1.8's to 1.73 on engine and 1.62 on nitrous. I have more than 300 passes on them so its time be getting a new pair or moving up to a slick. Our track is not the best prep'd track either. So do they 'stick' yep.
David
David
LS1Tech Co-Founder
Going from 15x8/26x10.5x15 ET Streets to a WIDER 15x10/26x11.5x15 combo might help, but adjustable front shocks up front might help even more why don't you give us more detail.
I have gone 1.51 (A4 car) on the 15x10/26x11.5x15 ET Street combo with front shocks at 1/1.
Ok, here is the info.
Car is an incon TT on 7-8psi of boost and is probably making 550+ to the wheels right now based on my last dyno at 4psi.
Here is my suspension:
-PA K-Member and A-Arms with solid mounts
-HALs on all 4 corners
-Spohn Adjustable Torque Arm (Pinion Angle -2)
-Global West Adjustable PHR
-Global West LCAs
-KBDD Subframes
-Wolfe 8pt Chromoly Cage
-Moser 9" w/35 spline axles and spool
-Airbag RR 25psi at the track
I have the front HALs set on 3 and the rears on 5, last time at the track was ~4psi of boost (460 rwhp) and I went 11.9 at 120 on a high 1.9 60ft.
I lowered tire pressure to 12 psi on the ET streets and the car still wouldn't hook, if I leave at 4000 it will spin the tires as soon as boost hits.
I think that my old ET Streets may be part of the problem because they have seen a lot of miles...in normal driving on 7psi the car will spin the tires if I punch it in 3rd gear on the freeway.
Thanks for the help!
Scott
-Global West LCAs
-KBDD Subframes
Scott
LS1Tech Co-Founder
With a turbo you make a lot of power at 4000 rpms.
Honestly you might benefit more from a 28x11.5.x15 ET Street setup.
I would not air them down lower than 12 psi I usually run 15psi and start to air down but never lower than 12 otherwise the car handles poorly...
I'd put the hal fronts at 1/1 and then tighten them if you can get away with it.
PSJ,
I will try changing the front HALs, do you think that 5/5 is ok for the rears?
Will a 28 x 11.5 x 15 ET street fit on a car without any massaging? I heard that with adjustable LCAs they will fit.
Scott
Scott
LS1Tech Co-Founder
I see folks running different #'s in back, but I would probably stagger them a bit...
Like 4 driver rear/6 passenger rear...
I ran 28x9x15 ET Drags on 15x8's last year and they are pretty much the same size you might need some fiddling.
I guess if you are looking for a 10 second pass I'd run 27-28's...
28x9x15's cutting only a 1.63 here-->
https://ls1tech.com/moderators/psj/p9150016.jpg
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>If you do get the 11.5 ET Streets, make sure you run with a 15x10 rim. They will bulge out and not make very good contact patches with an 8" wide wheel.
-Tony</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tony, are you saying that for a 15x8 rim a 10.5 would be a better solution that a 11.5? I was just getting ready to order some 26x11.5s today for my 15x8 prostars.
Will it hurt if I put my 26x11.5x15 ET Streets on a set of 15x8s and then move them to a set of 15x9.75 rims in a month or so? Will they wear funny?
Scott
Scott
