Drag Racing Tech
smallest diameter slick?
Old 09-01-2002, 10:55 PM
DriveATransAm's Avatar
Default smallest diameter slick?
what is the smallest diamter slick for a 16" rim?
right now i run 16" et streets- 26x10.5s. i can hook fine on 20 pounds of air in them. my 60s are high 1.5s right now. i wanna smaller diamter for a)better 60s and b) crossing the traps at a higher rpm. i still run a 3.23 gear and start to cross when im just making power. i dont want to change gears cause i drive the car a lot. i want a small tire <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . i "could" run a nitto, but i want a little more tire. is there anything stickier than a nitto and smaller than a 10.5 et street?
Old 09-02-2002, 07:20 AM
GeorgeC's Avatar
Default Re: smallest diameter slick?
I don't think you'll find anything shorter than a 26" tire (the actual height may vary a little from tire to tire), except for some of the slicks designed for front wheel drive cars (which you wouldn't want to use). Your best bet will be a Nitto or BFG, since you can get these a little shorter (but even then it's not much).
Old 09-03-2002, 08:38 AM
doh!
i was afraid of this <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> . i was looking for a 10-11" wide drag rim in 17" to mount some 315 nittos on. i hooked a 16" nitto to a 1.55 60', but again, track prep is not always going to be that good.
Old 09-03-2002, 09:14 AM
CHRISPY's Avatar
Their isnt a huge difference but I think the 26x10.5 ET street is a little smaller. (maybe 1/2 an inch?) I think it is equiv to a 26x8.5 ET drag which is 25.8 inches I believe.
Cheers,
Chris
Old 09-03-2002, 09:36 AM
dug
dug's Avatar
If you are willing to go with a 15" wheel you can use these M/T slicks
Size: 22.0 x 8.0-15
Tread: 7.9
Sec.: 8.6
Dia.: 22.4
Circ.: 70.0
Note: (1)
would look kinda gay but would be an easy way to give a m6 with 342s a better launch
Old 09-03-2002, 01:27 PM
im not willing to grind anymore to accomodate 15" rims (unless they fit no problem)
how much does that 8.5" drag grow in comparison to the ET streets? i need some new tires very soon.
Old 09-03-2002, 01:36 PM
!Dial-up Director
Sears's Avatar
Convo Pros and the special offset Bogarts from PPO fit without caliper grinding. They are 15"
Old 09-03-2002, 01:45 PM
GeorgeC's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by dug:
<strong>Size: 22.0 x 8.0-15
Tread: 7.9
Sec.: 8.6
Dia.: 22.4
Circ.: 70.0
Note: (1)
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Those are for a front wheel drive car, and wouldn't work worth a damn on a rear wheel drive F-body with any horsepower.
You might as well try some wheelbarrow tires on the rear. <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Old 09-03-2002, 10:11 PM
XFiveLiter's Avatar
Just get some gears already! You sissy <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
