Drag Racing Tech
Will a 15x10 weld fit w/28" tire?
Old 10-09-2002, 05:26 PM
theblur98ss's Avatar
Default Will a 15x10 weld fit w/28" tire?
I need to run a 28" tire. I have convo pros but since they stick out I can't run a 28" tire without cutting and beating so that's out of the question. Can I fit a 28" tire on a weld rim without modding anything other then the calipers? Open to suggestions.
Old 10-09-2002, 05:35 PM
onebad96T/A's Avatar
Default Re: Will a 15x10 weld fit w/28" tire?
Yes you can run a Weld Drag Light or a Drag Star 15x10 w/ 7.5" back spacing with a 28x10.5x15 slick
Old 10-09-2002, 05:53 PM
Colonel's Avatar
Seconding that yes. You *might* have to do just a little trimming of the plastic behind the tire which is really no big deal. Took me about 30 seconds with a sharp pocket knife (wonder why that word requires a "k".) Anyway, no big deal and you'd never notice the difference.
I run 29s now and that required some trimming and then touching up of metal in front of the tire. A little more involved.
Old 10-09-2002, 06:31 PM
D(irecto)r Pepper
Raughammer's Avatar
Front of the tire....the plastic fender had to be trimmed a bit.
But I run 28"x10.5 e.t. drags and a 15x10 Weld.
Good luck.
Old 10-09-2002, 07:00 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
Here are my 28x10.5x15 Hoosier slicks on 15x10/7.5 Pro Stars (no spacers)cutting a 1.49...
http://www.pbase.com/image/5269912
Also you can also maybe use adjustable LCA's to move the rearend front and back to minimize cutting.
Need to also deburr the front lower part of inner fenders, the lip... And hammer in the front inner part a little bit but not a lot... I was suprised how little clearancing I had to do.
