Drag Racing Tech
Will the Weld Draglite XP's fit......
Old 10-24-2002, 10:59 AM
ShadowZ28's Avatar
Default Will the Weld Draglite XP's fit......
I was wondering if anyone has the new Weld Draglite XP's? If anyone does do they fit without any grinding or spacers (front and back)?
Thanks
Joe
Old 10-24-2002, 06:11 PM
ShadowZ28's Avatar
Default Re: Will the Weld Draglite XP's fit......
TTT!!!!
Old 10-24-2002, 06:24 PM
gator's 99TA's Avatar
yes, they fit without grinding. but they weigh as much as stock!
Old 10-24-2002, 06:28 PM
ShadowZ28's Avatar
They weight as much as the ZR-1? Even the skinnys?
Thanks
Joe
Old 10-24-2002, 07:15 PM
MONGOOS's Avatar
smallest the XP's come in is 16x6 and at that size you may as well run factory 16x8's all around.. it would be cheaper.
Old 10-24-2002, 09:07 PM
98TAauto's Avatar
the 16x9's i have weigh almost as much as my 17x9 Z71's
I run the 16x9's on the rear with 245/50/16 nitto drags, and on the front I run the 15x3.5's skinnies with a spacer
Old 10-24-2002, 10:16 PM
roadrunner-r's Avatar
What rim is lighter?
Old 10-25-2002, 04:03 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by roadrunner-r:
<strong>What rim is lighter?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">im lost??? the 15inch welds will be the lightest you can run but you have to grind the stock rear calipers for them to fit
the weld XP's are like and weigh just like any other 16inch rim... they weigh just as much as my 17inch ZR1's
