The O.F. gets closer ... - LS1TECH
Thread Tools Search this Thread
Old 08-10-2004, 01:58 PM   #1
Default The O.F. gets closer ...
... to the elusive 10's. Ran a best of 11.14 @ 122.98 on a 1.59 short. Spins too much in first. I've softened up the clutch enough that it hooks until the front end bangs into the shocks (QA-1s) and then the slicks break loose. Ran the tire pressure low enough that it got real squirrely (6.5 PSI), but the 28x10 Hoosiers on 8" rims seem to like 9 PSI best. I had the QA-1s on 3 and will try higher to stop the violent front end lift. I'll try 5.13 gears to see if I can't get under 1.5 shorts, but the rest will have to wait untill I fix the motor. It didn't perform up to my expectations (another one of those "low performing PP headed cars") so I ran a leakdown. 43%, 33%, etc with the best being 12%. I think it might pick up a bit with new rings (and maybe pistons), but I have no idea how much.
critter is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
