ls1 vs. lt1 - LS1TECH
ls1 vs. lt1
Thread Tools Search this Thread
Old 11-10-2002, 10:15 PM   #1
Default ls1 vs. lt1
what is the difference in 1/4 mile time between an ls1 and an lt1?
WLRIII is offline   Reply With Quote
Old 11-10-2002, 10:56 PM   #2
LS1LT1's Avatar
Default Re: ls1 vs. lt1
Stock:
LT1 = 13.8 - 14.3
LS1 = 12.9 - 13.5
Depending on transmission, driver and track/air quality of course. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
LS1LT1 is offline   Reply With Quote
Old 11-11-2002, 02:04 PM   #3
Administrator
unit213's Avatar
I've yet to see a NA LT1 run quicker than 13.8.
unit213 is offline   Reply With Quote
Old 11-11-2002, 03:54 PM   #4
99MONGOOSE's Avatar
I have seen a lot of NA Lt1s run quicker then 13.8, not stock of course. My old car was a 95 LT1 formula, and check this out:
-1995 formula loaded with cloth interior and t-tops, A4 with 2.73 gears, goodyear RSA allseasons
-stock everything except:
HPP3-used to firm up shifts, remove 117mph limiter, turn fans on @ 160', and I messed with the shift points and MPH, and I used the power tuning for a stock thermostat
-I added a K&N FILTERCHARGER(replaced the entire airbox assembly)
With only these two mods I went from a stock 14.4@98mph to a 13.9@101mph! Thats was one fast car for what it was. The best thing was I cut off the bump stop on the shifter so I could manually shift into low 1 or 1st gear. On the Firebirds there was a little rubber/plastic stopper on the shifter assembly that wouldn't allow the shifter to be pulled all the way down into 1st gear, and the shifter readout only said 2-D-OD-N-R-P instead of 1-2-D-OD-N-R-P. Only the cars with 2.73 gears had that blocker on them, but with it removed I could grab 1st gear at almost 50mph and still have some gear left. I am not joking either, when that car shifted into 3rd or "D" I was within 2-3 cars of the finish line at the 1/4 mile track.
99MONGOOSE is offline   Reply With Quote
Old 11-11-2002, 04:15 PM   #5
WhitePheonix's Avatar
I love every single f-body ever made, but the LS1 offers the best performance money can buy period. The only positive side to the LT1 is parts are plentiful and much cheaper then the ls1. Of course you have to then compensate for the horsepower difference between the two, by doing more mods to the LT1.
WhitePheonix is offline   Reply With Quote
Old 11-11-2002, 11:32 PM   #6
Wow, when i had my 97 Formula with 2.73 gears, A4, with 60some thousand miles on it i ran a low 13.8 with CAI and SLP loudmouth as my only mods. Of course i did 'some' weight reduction. I took out the front right passenger seat, left rear bucket seat (not the back), door panels, tire & jack, and the insulation and stuff in the back trunk area. With very little money mods, and weight reduction LT1s can get 13s easy. Course a stock LS1 will run low 13s all day, so LS1 > LT1 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Black Death TA is offline   Reply With Quote
Old 11-12-2002, 06:06 PM   #7
Ls1's are a better engine...to contend with an LT1 which I have I must say...you gotta do the LT4 conversion. The LT4 is rated at 330 hp and fairly so is an Ls1 in say an SS.
Either way you go you can go fast with the right parts.
hank
REDLINEZ28 is offline   Reply With Quote
Old 11-12-2002, 06:08 PM   #8
Moderator
BADZ's Avatar
You should try the drag racing section on this topic...
moving
BADZ is offline   Reply With Quote
Old 11-12-2002, 07:12 PM   #9
My 97 Z28 went 13.8s dead stock at 1300ft of elevation. No weight reduction.
The real difference I suppose is the goal for the car. How fast do you want to go?? For a car going faster then 10s (9s and faster) an LT1 is a much simpler, cheaper, and easier breed.
An easy Bolt-on or heads/cam car though the LS1 does seem to be the hot ticket.
[Flame Suit On]
<small>[ November 12, 2002, 06:13 PM: Message edited by: KTamez ]</small>
KTamez is offline   Reply With Quote
Old 11-12-2002, 08:35 PM   #10
i ran 13.81@101 in my 96 SS 6-speed when it was completely stock with no weight reduction. i put some et streets on and then ran a 13.59@103. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
cenman is offline   Reply With Quote
Old 11-12-2002, 09:30 PM   #11
big dave's Avatar
My 94 Z ran 13.64 @ 100.4 factory stock. My friends 6speed 95 Z28 ran 13.67 @ 102.7 factory stock. Just because you haven't seen it doesn't mean it hasn't been done.
big dave is offline   Reply With Quote
Old 11-16-2002, 07:14 AM   #12
Fahad's Avatar
My old car is Trans am 94/M6
With only these mods.
( 3.73 gear ratio , hpp3 , fipk k&n , borla exhaust system ,
ported mass air and intake , underdrive crank and alternator pulley ,
edelbrock headers , Ypip , MSD wires , NGK TR55 , hurst shifter ,
some free mods )
Note: After I transfer from A4 to M6 I felt that my car is much better than befor .
access : bugatti wheels 17"*9.5 chrome
my best time ( G-teck ) : 13.12@112.33 (stock tires and clutch)
Thanks.
Fahad.
Fahad is offline   Reply With Quote
Old 11-16-2002, 08:13 AM   #13
Administrator
unit213's Avatar
"My 94 Z ran 13.64 @ 100.4 factory stock. My friends 6speed 95 Z28 ran 13.67 @ 102.7 factory stock. Just because you haven't seen it doesn't mean it hasn't been done."
That's a fairly low mph for 13.6's. Those times were probably on sub 2.0 60'.
Old 11-16-2002, 05:11 PM   #14
RAGEman's Avatar
I've seen several completely bone stock (meaning EVERYTHING) '01 and up LS1's run 13.1-13.4 @ 105-107. When I bought mine, I greatly preferred a NEW car over a used one, so there wasn't any decision to it for me. Here are the differences that one must weigh when they make the decision:
LT1
-cheaper
-slightly cheaper to modify
-less power from the factory
-more developed aftermarket (by about 5 years give or take)
-older
LS1
-more expensive
-more expensive to modify
-more power from the factory
-less-developed aftermarket
-newer
Mustangs
-junk <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> (Just kidding, don't get your panties in a wad)
Does that about cover it?
RAGEman is offline   Reply With Quote
Old 11-18-2002, 02:09 PM   #15
RAGEman's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ou812/z28:
<strong>i have a freind that ran an 13.00 all stock with an lt-1 and yes it suprised me. all it had was 4.10 gears/</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Man, I don't know how you hit the "T" on accident cuz the "S" is all the way over on the left side of the keyboard. Might want to fix that. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 11-18-2002, 02:15 PM   #16
LOL <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 11-19-2002, 01:49 AM   #17
ou812/z28's Avatar
ou812/z28 is offline   Reply With Quote
Old 12-08-2002, 09:41 AM   #18
NastySSoo's Avatar
I never cease to be amazed at the BS you read!!
NastySSoo is offline   Reply With Quote
Old 12-08-2002, 09:44 AM   #19
Z06PSI's Avatar
I have had both and there was no comparison between them. The Ls1 just pulls so much harder and longer it was like night and day.
Z06PSI is offline   Reply With Quote
Old 12-08-2002, 12:16 PM   #20
Patman's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by camaro_ls1:
<strong>I've yet to see a NA LT1 run quicker than 13.8.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mine will next year, I guarantee it. I ran a 13.89 at 98.2 in bone stock trim this year, but I later found a bad vacuum leak and I also replaced both o2 sensors and it's running way better since. I ran at the track once after that but only ran a 14.04, I spun all through first and into second and even got rubber on the 2-3, all because the track was very cold and in poor condition. I estimate my car should run a 13.7 no problem on a good track day, with zero mods. It's a low option 95 Formula, 3.23 A4 hardtop. Curb weight on a half tank is 3440.
<small>[ December 08, 2002, 11:19 AM: Message edited by: Patman ]</small>
Patman is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Lt1 hp tuners lt1camaro383 LT1-LT4 Modifications 4 03-09-2015 08:36 PM
the new LT1 heads and LS7 block Abdullah Generation V Internal Engine 4 11-11-2013 03:58 AM
24x leftover pins? mtt14 LT1-LT4 Modifications 11 11-21-2012 05:53 PM
Ls1 cam into lt1? christiandoy Generation III Internal Engine 64 10-27-2012 09:52 AM
LT1 Heads Removal bambam6464 LT1-LT4 Modifications 3 07-01-2011 07:37 PM
Tags
14, 1996, 1st, camaro, gear, ls1, ls1vs, lt1, mile, stock, stopper, weight, wheigh, ypip, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
