Drag Racing Tech
Full fuel tank?
Old 11-20-2002, 05:14 PM
NC Guy's Avatar
Default Full fuel tank?
I'am going to run my bone stock M6 2000 SS on the original Goodyear F1 tires.
Should I run with a full fuel tank to aid in traction?
Or...run with as little gas as possible to shed weight?
Thanks for informative replys.
<small>[ November 20, 2002, 05:58 PM: Message edited by: Pro Stock John ]</small>
Old 11-20-2002, 07:28 PM
WJ SOM SS's Avatar
Default Re: Full fuel tank?
1/4 tank, or a little less. Shed the spare, jack, and anything else floating around in there. Pounds are tenths! WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 11-20-2002, 09:05 PM
NC Guy's Avatar
Thanks for your reply 99 SS,
I agree that pounds are tenths and every bit counts. I'll take your advice and remove the 'extra' stuff.
Can anyone else shed light on this subject?
Old 11-21-2002, 07:54 PM
CPHOSS's Avatar
I also agree that pounds are tenths, but ONLY if you can get traction. Track prep and outside temperature will be a key factor in traction. I have tried both ways(1\4 tank and full tank) on street tires and it did not seem to make much of a difference either way.
Old 11-21-2002, 08:30 PM
AFTICA's Avatar
I've always believed that less fuel/weight was better for ET. However my best 60ft times (1.71 on Nittos, need to change the sig) have been with an almost full tank. If your traction challenged I'm starting to believe that a full tank will help ET's, since what you would gain in traction would be far better for ET than what you would gain with less weight. That will not be true if your dead hooking with a full throttle leave though.
Old 11-21-2002, 09:45 PM
Colonel's Avatar
Even when traction limited I like less weight. I just adjust my driving to suit the traction. I used to cut consistant 1.5 60 fts on Nittos with WAAAAAAAAY more power than they could handle. I just had to figure out how to drive the car like that (I can tell you I was leaving the line nowhere near WOT!)
