No swaybar??
No swaybar??
What can I expect to happen when I run with my swaybar off. Is it going to be hard to steer?
I'm mostly stock so is removing it neccessary or would loosening it up be sufficient/safe? If just loosening it is cool, how much, almost all the way?
My car is lowered so I'm sure it will appreciate the weight transfer. Any idea how much I'll gain in the 1/8-1/4? Thanks guy's.
Re: No swaybar??
It'll certainly help weight transfer. Loosening it all the way up is just as good as taking it off except you won't get the weight loss.
Steering effort will be the same. The car will lean more in turns.
Re: No swaybar??
I would just take it all the way off. I had a friend who just loosened it up. When he launched the first time at the track the front end came up hard enough to break one of the end links.
