Drag Racing Tech
BFG Drag Radials or ET Streets???????
Old 12-28-2002, 07:23 PM
Ole Blue's Avatar
Default BFG Drag Radials or ET Streets???????
Which tire will have to quickest 1/4 and the fastest MPH????????????????
Old 12-28-2002, 07:37 PM
Coal Mining Director
onfire's Avatar
Default Re: BFG Drag Radials or ET Streets???????
On a less than great prepped tracK, the ET streets will kill the BFG's....I've tried both.
Old 12-28-2002, 09:38 PM
mike c.'s Avatar
i agree with onfire,i've had better luck with the et streets.
Old 12-28-2002, 09:39 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
never tired bfg's, but never heard much good about them. I've been running ET streets for 5 years and had great success!
Derek
Old 12-29-2002, 02:34 AM
taqwache's Avatar
et streets will provide alot better traction then BFGs but they sux for every day driveing if that bothers you. i have also tried both and i am currently running the BFGs right now. this is mainly because i have to drive 160 miles to the closest track and this is not fun on the ETs. i dont have any complantes on traction from them since they hooked up good enought to break my left axle shaft on my 10th launch with them. also there is two cars from SAM school in houston doing 9s with them on motor.
Old 12-29-2002, 09:35 AM
ezss's Avatar
Depends on your setup -- without a 12 bolt I wouldnt recommend ET streets -- you will bust your rear. Without around 360+rwhp and decent gearing (~4.10+) you will most likely loose ET on ET streets, or certainly not see the type of advantage you were looking for.
I've run BFGs and 2 different sets of ET streets (on 16" and 15" rims). The BFGs I never had better than a 1.90 60', but once you got going they didnt spin anymore, so vastly superior to street tires and you can drive to the track with them. The ET streets I change at the track, they are too sticky and wear too easily for street driving in my opinion.
My car is an M6, so results vary --I know people doing 1.60 60's in an A4 on BFGs.
Old 12-29-2002, 10:55 AM
Colonel's Avatar
"without a 12 bolt I wouldnt recommend ET streets -- you will bust your rear."
Not likely to happen if he's running an A4.
Quite often it's wheelhop that gets a rearend...especially with an M6. ET Streets are less likely to wheelhop than radial tires. I busted a stock rearend once with Nittos due to wheelhop...well, that and 500 RWHP! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 12-29-2002, 10:53 PM
taqwache's Avatar
dam colonel i wish my 10 bolt lasted that long. i broke my axle shaft with a completly stock engine including stock air box and filter with little baby 2000rmp launches, BFG DR and no wheel hop. i guess it is just bad luck on my part.
Old 12-30-2002, 09:38 AM
Ole Blue's Avatar
Which tire will have a higher MPH???????
Old 12-30-2002, 08:18 PM
Drew778's Avatar
The BFG DR's should have a higher mph. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I plan on getting Nitto DR's for everday driving.
Old 01-01-2003, 11:48 PM
Nice4thgenZ's Avatar
i drive everyday on nittos but i use et streets for the track
