Drag Racing Tech
Now that my roll cage is installed, is there any need for subframe connectors?
Old 01-02-2003, 01:00 PM
verbs's Avatar
Default Now that my roll cage is installed, is there any need for subframe connectors?
I was gonna get some, but wasn't sure if the welded roll cage does what the subframes would do.
Is it pointless to do subframes with a cage?
Old 01-02-2003, 03:02 PM
Sparky's Avatar
Default Re: Now that my roll cage is installed, is there any need for subframe connectors?
I think you should, IMO. In fact, I'd get the subs and have the rear of the cage (behind the seat) welded through the floor and into the subs.
Rock solid!
Mark
Old 01-02-2003, 03:58 PM
99ragtopSS's Avatar
I have a 6 point custom in my vert and did forgo the the sub-frame connectors, I didnt see the need with the 6 point. With a cage it keeps you flat and solid. Just my $.02
Old 01-02-2003, 04:44 PM
LS1Tech Sponsor
MADMAN's Avatar
You definetly need subframes. The cage IF properly installed SHOULD be welded to the subframes.
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-02-2003, 09:06 PM
Bill00Formula's Avatar
Just wondering - If the cage is attached to the subframe connectors, would that require a custom cage versus a wolfe cage?
Old 01-03-2003, 01:10 AM
bigSS's Avatar
I would. In many cases roll bars are not attached to the subframe of our cars.
Old 01-03-2003, 06:42 AM
LS1Tech Sponsor
MADMAN's Avatar
The wolfe can be welded to the rear of the subframe where the main hoop sits on the floor.
__________________
225-343-9029
Quick Reply: Now that my roll cage is installed, is there any need for subframe connectors?
