New best with my baby cam combo
Went to Steele today for some runs with a bunch of guys from Chattanooga. DA was 800 ft.
I got a new best in my Camaro
11.31@120
Heads ported by me with the help of my friends at tea (I did them when I worked there with help of some of the porters there. I was a machinist not a head porter so I am happy with how they turned out.).216/220 comp cam. Hooker long tubes and a tp4400.
3400 lb raceweight.
11.31@120
3400 lb raceweight.
Re: New best with my baby cam combo
yeah it doesnt sound like much <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> since I run with the stock cat back it is real tame.I open the cutout to make passes but close it on the return road.Makes for a nice quiet ride
I am going to change cams soon maybe the 227/224 thunder cam or something close to it.
Congrats on the new best <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
What were your other runs and 60's ? Sorry to here the DA was not that good. When is that bigger cam going in? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
that was on a 1.56 60 ft
then a 34 0n a 1.58
then a bunch of 11.40's on 1.6+ 60 ft times.
I think I need some tires <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Too Bad you didnt make it.
Weather wasnt bad just not that mineshaft air we all love <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
then a 34 0n a 1.58
Thanks ,
Cam should be going in soon.I am gonna look at your car hard though I really think the little cam will work good enough to get me into the 10's if I could hook car.
I need to try some new tires maybe on a 15x10 rim,cant get enough tire on the ground with these stock rims.
What is your ICL on that cam? Did you install it with the dots matching? What lift?
I just installed a 218/218 and lost 60'. It is on a 114 ICL installed with the dots. Gained a slight et and mph.
216 / 220 .525 / .532 114 LSA
I installed it straight up Larry. I am using the stock timing chan and gears . I am going to swap to a dual chain when I do another cam change.
My car seems to make very good low end power..Cant tell for sure with tp4400 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> But I cant hook for crap.
So far my best pass has been on my best 60 ft a 1.56
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by H82BBad:
<strong> 216 / 220 .525 / .532 114 LSA
So far my best pass has been on my best 60 ft a 1.56 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Is your cam ground on a 114 Intake Center Line(ICL) or does it have advance ground into it? You can find this on your cam card.
I ran a 1.58 60' with the 01 LS6 cam but slightly less mph than this cam. Slowed to 1.65 60' with this cam. I need my 60' back if I'm going to improve my et. That's why I think I have too little advance.
What rpm is your tranny shifting?
Sorry Larry I dont have info anymore.It is an off the shelf grind.
I shift 1-2 @ 6550
2-3 shifts at 6350
I moved since I did this and dont have the cam card anymore.
Thunder stocks this cam. I would call them and ask them to look at the cam card for you.
Whats the lift o your cam? .566? we installed one like that on a friends car idles great and made 400+ rwhp.Its a nice cam. Did you loose low end power with it? Or are you spinning now?
I shift 1-2 @ 6550
2-3 shifts at 6350
Your converter being looser than mine might explain why you are getting better 60' and et than I am. Should not account for that much more mph than me. I had a lower DA than you and only ran 115.84 mph. Or your cam has advance ground into it. Maybe a 110 ICL or so. Most cams do have some advance ground into them. My lift is .528 in and ex. I don't have a traction problem.
Your shift points are higher than mine. I shift about 6000 but that is as high as I can get my 1-2 shift without programming and about 6200 on the 2-3 shift.
With my 60' down I am sure my low rpm torque is less although on the top end I am getting a little more due to slightly higher mph. I just feel that more advance is required to take advantage of my cam.
If you could get your ICL I sure would like to know so I will have a better handle on how much to advance my cam. Thanks!
I was down there Sat with my 2002 and Sunday with my 98 and my 2002, which car was yours? I'm looking for a "small" cam for my 2002 and my stock heads. Did you have your car tuned with LS1 edit on a dyno after the cam.. or do you still have stock programming?
My car is the black 2000 Z-28 with the SS hood and michigan plates.
I tuned the car with edit on the dyno.Dont ask my non dynojet numbers they are embarrassing. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
And I wont tell.!
I was parked bside the Blue Viper and the pewter camaro and red rx-7
I would use a straight durration cam if you dont want to do tuning. While this car has a small cam I think a 216 or a 218 cam straight across will idle better than a split.
And I wont tell.!
