Drag Racing Tech
anyone run Bogarts w/ ET Drag 15x10.5x28?
Old 01-14-2003, 10:40 PM
T/A Medic's Avatar
Default anyone run Bogarts w/ ET Drag 15x10.5x28?
If you do I was wondering if u had to put screws in the rim to keep from spinning the beed...
I ran 10.735 on 16s/ET Streets without putting screws in them. Was hoping to not have to damage the rims.
Thanks
Jason
Old 01-14-2003, 10:45 PM
Colonel's Avatar
Default Re: anyone run Bogarts w/ ET Drag 15x10.5x28?
Bogart's website says you do not have to use rim screws with their wheels.
Old 01-14-2003, 10:56 PM
SJM Manufacturing Inc's Avatar
Screw's shouldn't be needed.
Don't run your tire pressures abnormally low. You can put a mark using chalk or an vis-vis pen over the rim and tire to be sure that your not spinning it.
You can run 11.5's on it as I have which will "pinch" the tire more on the rim.
Steve
Old 01-14-2003, 11:09 PM
T/A Medic's Avatar
the only reason I ask is because Im putting a 200 shot 1x maybe 2x to a stock bottom end and 10 bolt... and I dont want to get a slower ET cause they spun the beed.
Old 01-14-2003, 11:46 PM
Stu'sWS6's Avatar
TOSTO RACING's '01 SS has Bogarts and 28x10.5x15 MT et drags-no screws on the rims. I have seen Tim run his slicks pretty low-around 10 psi with no spinning on the rim. Your 10 bolt is not going to like those tires, mine didn't <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 01-15-2003, 12:10 AM
The BeaSSt's Avatar
Screws here. The website may say no screws but when I ordered them they said to screw em.
Dave
SAM 436
www.thebeasst.com
