Help me pick out the correct Prostars and slicks
Setup: TP4200, TR230-cam, 3.73 and all bolt-ons
I'd like to cross the 1/4 traps at 6400rpms
Thanks in advance for you suggestions
Re: Help me pick out the correct Prostars and slicks
15x8'S AND 26x10 15 E/T Drags will get you to cross the line near that rpm.
IMO you have no need for heavy 15X10's, nor do you need the tire height of a 27 inch tire.
With a tp4400, 4.10's, and 26X10 15's I crossed the traps right around 6500-6600 when running 121+ mph.
I'd say 15x8's and 26x10.5x15 ET Streets. Its the shortest 26" tire that I could find at 25.8". And thats exactly what you need with 3.73's. Even with the tire I suggested, it might not hit 6400rpms through the traps.
later,
Steve
later,
Steve
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mike Hoffpauir:
<strong> 15x8'S AND 26x10 15 E/T Drags will get you to cross the line near that rpm.
With a tp4400, 4.10's, and 26X10 15's I crossed the traps right around 6500-6600 when running 121+ mph. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You're the man I'm listening to! I'm actually trying to match or beat your times with the almost identical set up <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Are you running 15x8 wheels in the rear?
So 26x10 Hoosiers on a 15x8 rim will work for me?
Yeah I am running 15X8's in the rear. I have no experience with hoosiers, but the size is the size reccomend.
A hard hitting TC and 3.73s is why i recommended a 27" tire.
My car with the 9" and 3.50 gears 60 footed the same on 28X10's as it did on 26X10's.
But on bottle you tell me how the car reacted??
You dont have to run the 10" rim but i still suggest the 27 tire. Dead hooking is where its at!
Texas Director
I strongly recommend that you go with 15" x 10" Welds instead of 15" x 8" if using a 26" x 10.0" x 15" slick. You'll get a much flatter tire tread surface with the 15" x 10" as opposed to a bowed surface with a 15" x 8".
How nicly do 15x8 Weld Draglites on a 5.5 BS tuck under the fenders. Do they stick out or do the tuck up in to the fender wells nicly? And since a couple of you are saying that 10" is too wide, what width do you recommend?
With tires like ET Streets, drags, QTP's etc etc Running a up to a 10.5" tire on 8" wheels is fine unlike a radial tire you do not get tread cupping due to the more flexable sidewalls Youll be fine with an 8" wheel - and it will be lighter than a 10" wheel
My car, with the 10.5 Et Streets, and the 10" Et Drag's, shifts into 4th gear, just before I cross the line. Rev limiter is set at 6600. Every car id different. I suggest that you borrow someones tires & find out what RPM you are at, & buy your tires based on that. Otherwise, it's just a shot in the dark.
Texas Director
For Weld wheels for the F-bodies you need a 4.75" lugnut bolt circle.
15" x 10" wheels need 7.5" backspace
15" x 9" wheels need 6.5" backspace
15" x 8" wheels need 5.5" backspace
BTW, the 15" x 10" wheels fit tuck under the wheels wells with no problem. I am running 15" x 10" Pro-Stars with 26" x 10.0" x 15" ET Drags and have zero issues.
Thanx <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> mmiller good info! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
