Best dragtire to get?
I need some input from you guys. The track is reopening after 2.5 years and now its time to get the car ready. I currently have 15X10 Prostars with 7.5in BS.
I ride on BFG 275-50-15s for everyday use. My car roasts these from a takeoff with no problem, on the track or the street. What tire is the most recommended here?
ET Drags
ET Streets
QuickTime Pros
I can't go bigger than 26in tall because I have custom PCM tuning from Ed Wright and going taller will screw with my shift points(A4) I wish I could go with 28's because I have a handle on a local set of ET Drags for 200 bucks with 4 passes on them. But I don't want to pay or send my pcm back to ed for a basic change that he will charge me for.
Help me out, I want to hook good come March 1st.
J <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
ET Drags
ET Streets
QuickTime Pros
Re: Best dragtire to get?
Thanks Texcamss, the best 60ft on the drag radial was a 1.90, but stayed in the 1.95 range. It spins those things bad. Time to order a pair of ET Streets. That seems to be the perferred choice in my area and on the boards.
Thanks and hopefully I will have some decent numbers to show before I put the Forged 348 in with some more boost thrown at it.
J <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
"All Motor 9 Second club member"
I have a set of 26x11.50-15 ET streets that have only 8 passes on them. I will let them go for $200.00 . They hooked good when the track prep was good , but became inconsistant as the night went on. I needed a solid hook to be competitive in the bracket racing so I had to go to the ET Drags. I am located in the Houston Tx area. Let me know. Take care.
James
James
I had some et streets they were ok, now I have 27x11.5x15 Hoosier QTP's, they held up nice on motor, I will see how they do on boost off a brake... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
