Hot Drag Car Porn...okay 60ft questions
Hot Drag Car ****...okay 60ft questions
Okay, new launch technique needed. Here is the setup!
98 Camaro SS M6
HPM Mega Bite Torque Arm (excellent)
Moser 12 w/ 4.10 gears
Spohn Relocation Brackets
Wolf Racecraft Sway Bar (Big Sombitch)
Eibach Drag Launch Spring and Airbag
HPM Trailing Arms/SFC's tied to Torque Arm
MT ET Drags 26/10/15's on Weld Draglites
6 point welded in cage
Can I possibly hit a 1.30's 60 ft time? I have the horsepower, the car is as tight as a virgin on her wedding nite. My previous best 60ft time was a very disappointing 1.88 60ft w/ 11.77 @121 mph, with a: Dry NOS, Nittos,Trailing Arms, and Eibach prokit...nothing else. Please humor me, and tell me 1.30's are possible...okay dont humor me, be honest. The key to me hitting my goal of a 10.8 on stock internals depends on the $3500 I just spent on 60ft time related parts!!!
<small>[ March 10, 2003, 03:36 AM: Message edited by: Fast SS on NOS ]</small>
98 Camaro SS M6
Re: Hot Drag Car ****...okay 60ft questions
There has only been 1 stick LS1 with a 60 that low, its the SAM car it dose high 1.2's i think. I remember seeing a few high 1.3's.(Allen Futral)
you are not going to get it done with those tires, you ginog to need somthing BIGGER at least 28in. with a 10+ in. tread width. I run a goodyear eagle 28x10.5x15 D3 compound.
Are your ET drags stiff sidewall for a stick car?
I have cut a best sixty of 1.48, on that run I left at 6400rpm's ON the spray (150 wet shot)Dead hook.
I hope you didn't get the eaton posi with the 12-bolt because it wont last, mine didn't only 3 passes and i destoryed the spider gears. You'll need a Full spool.
My suspension consists of BMR long arm, BMR lca's,relocation brackets,rear hals,RR airbag,addco 1-inch sway bar, all stock up front except no sway bar.
I don't think your the spec clutch will work either.
I'm sure Coach will pop in here and offer up some of his advise.
<small>[ March 10, 2003, 06:36 AM: Message edited by: Gimp98TNT ]</small>
You'll never hit 1.3s or even 1.4s with that setup, but if you switch over to a wet juice setup (and run like a 175 shot), you might hit a high 1.4 at the right track.
My bad, I must of confused you on my new setup vs. my old setup
Old:
11.77 @ 121mph w/1.88 60ft time
NOS Dry 125, stock suspension, Nitto Drags, HPM trailing arms,stock 10 bolt w/4.10 gears, NO relocation brackets and no cage. Z06 clutch went belly up! I had the motor work done and juice, thats about it.
NEW:
TNT F1, Moser 12 w/Spool & 4.10 gears//Wolf Racecraft Sway Bar//HPM Torque Arm//Eibach Launch kit//Spohn Relocation Brackets//6pt Welded Cage// HPM TA's,SFC's and adjustable panhard//Lightened the car down to 3350lbs//removed front sway bar//Weld Draglites//MT ET Drags 26x10x15....Maybe that list will help a little more.
I am also adding HAL shocks (front and back) and will go to a 28" slick...What else can I do???
I have the MPH for an easy 10.8 but the hook has got to be right on the money!
<small>[ March 10, 2003, 04:43 PM: Message edited by: Fast SS on NOS ]</small>
Old:
NEW:
