Drag Racing Tech
A.C. Delete has anyone.......
Old 04-22-2003, 06:55 PM
smeshey's Avatar
Default A.C. Delete has anyone.......
Has anyone deleted all of the AC crap from the engine compartment. I mean how difficult is it to remove the inside bolts and does the heat still work?
Old 04-22-2003, 10:12 PM
BIGBOS's Avatar
Default Re: A.C. Delete has anyone.......
Heat will still work, compressor, condensor, and all the lines will come out, takes about 20-25 minutes w/proper hand tools... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 04-22-2003, 10:21 PM
T/A Medic's Avatar
I think he means EVERYTHING about the a/c including the bigazz box in the compartment... that was a bitch to get out... had to break the box it was contained in .... i wouldnt recommend taking the condser out unless ur motor is out or u can get the dash moved to pull it... i didnt feel like keepin my Heater and Such, but my buddy in his LT1 did it...
but here is befor and after
Before!!!!
<img src="http://www.wckdbrd.net/byebye.jpg" alt=" - " />
After !!!!
<img src="http://www.wckdbrd.net/bay.jpg" alt=" - " />
Old 04-23-2003, 04:17 AM
oOoLy's Avatar
How much of weight should i will lost ?
Old 04-23-2003, 07:49 AM
Larry's Avatar
I bet that makes that number 8 plug a little easier to get to.
Old 04-23-2003, 08:00 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Removing your A/C and heater box makes a world of difference in the engine compartment. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
All kinds of room to change plugs. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
I think we saved about 43 pounds by removing everything. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Coach
Old 04-23-2003, 09:43 AM
Super Moderator
Reckless's Avatar
Is there any way to keep you heat if you pull all that stuff out?
Old 04-23-2003, 03:34 PM
smeshey's Avatar
Ya I would lIke to keep the heater gets a little cold here in oct. So does anyone have picks or can tell me how to keep the heater?
Old 04-23-2003, 03:53 PM
ROB'S SS's Avatar
Tom The Roofer bought an aftermarket heater from Summit. something like that will work just fine for keeping the heat. there are plenty of aftermarket heaters you could use from electric to water fed. JC Wittney sells quite a few heaters
Old 04-24-2003, 07:31 AM
Super Moderator
Reckless's Avatar
I remember that now. He mounted it in the dash so it would blow out of the dash (defroster style). Actually a good idea.
Todd
Old 04-28-2003, 10:55 AM
Bombguy99z28's Avatar
I've done the same, and eventually need to pick up an electric heater to put in the dash. Besides taking everything out, you need to fabricate the blockoff plate (like the one in the picture, that is well done) and blockoff the two holes in the waterpump.
