Tire Size?
Tire Size?
Do 28" Tall tires fit without any modifications?
I'm trying to decide between.
BFG DR's
275*60*15 = 28"
or
275*50*15 = 26.1"
Also what size should I use with a 15*4 front wheel?
I was considering
M/T SPORTSMAN FRONT's
26x7.50x15LT 8ply = 26"
Thanks,
<small>[ April 23, 2003, 09:27 AM: Message edited by: HOSS99 ]</small>
BFG DR's
275*60*15 = 28"
or
275*50*15 = 26.1"
I was considering
Thanks,
Re: Tire Size?
You shouldn't have any fitment issues with a 28" BFG drag radial, since they don't grow at high speeds like a slick does...
The front tire you mention would be fine, or you could take the cheap route and just use a 165R/15 radial tire (which would probably be better, since you'd have radials on the rear, also).
Re: Tire Size?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by HOSS99:
<strong> Thanks,
Is the 165/R15 the VW tire from Pep Boys?
Is it safe for 110-120 mph 1/4 mile sprints? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep, that's one place to get them... Hopefully this won't start up an argument, but I believe they're perfectly fine for 1/4 mile racing. I wouldn't want to run at high speeds for extended periods of time, though.
I had them on my car for quite awhile, but switched to a taller tire (Moroso DS-2 28x4.5).
<strong> Thanks,
Re: Tire Size?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by houseofboost:
<strong> What is the biggest ET Street I can fit under my 1996 Camaro Z28?
Thanks a bunch,
Wes </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's too vague of a question to have a good answer for...
What size wheel? Are you willing to trim the rear bumper cover? Are you willing to massage the inner fender area? You can fit a big tire if you're willing...
Thanks a bunch,
Re: Tire Size?
My bad.
I will probably be running a 15x8 or 15x9 Weld drag pro star.
If not that, 16x8 stock camaro wheels.
I don't know about trimming anything, but I can do some massaging. I had to do a little to fit the 315/35/17 tires on it.
Thanks again,
Wes
Thanks again,
Wes
