My New Setup
My New Setup
Well, got the forged 347 coming from APE. Ordered the G5X3 on a 112 today. I'm not screwing around with the comp lifters so I ordered new stockers. oilpump from APE. Ive decided to put in a spool with 4.56s, and ordering new 33spline axles since mine have twisted after hundreds of passes. Ive broke the eaton posi before and I just dont want to screw with it anymore. I think these gears will help with my 3600# raceweight and big cam. Im not changing the raceweight since I drive it daily and like the interior and a/c. I drive on the street with a comp TA so I dont think the spool will bother me as bad as with a sticky tire. The heads are being disassembled cleaned and inspected and well see what they recommend. My h/c package had 44k on it with absolutely no issues at all. Thanks MTI for your badass heads! The motor will be 11:3 . Also going up to 01 injectors.And my T56 has still NEVER been touched with 83k and I swear to god over 1200 passes at the track!!!!! The only thing Ive done is clutches and changed the tranny fluid at 40k and refilled with Dexron III from GM. Realisticly Im hoping to knock a few tenths off with the new set-up so rock bottom 11s will make me happy!!
Paul
Paul
It definately treated me well. Its first pass at the track was at 500 miles. Its last pass was at 83k, and I still drove it home. You gotta love a chevy smallblock. They are happiest when its on the mat!!
i give it 10-20 passes before you're kicking yourself for not getting R lifters. i've seen 3 motors in the last month or so take a dump with cams similar to the G5X2 (which i wouldn't have chosen for that setup but it's your setup) because of trashed lifters. good luck...you'll need it.
Originally Posted by NastySSoo
Ill check with you first in the future!
i was just recomending the R lifters over stock, the morels are actually what are in my solid roller motor. i didn't know that morel made hyd. lifters for these motors. i didn't "demand" you do anything with yoursetup, i just gave my opinion. but what do i know, i only work on late model GM motors all day long. i guess those 300+ cam swaps and all the things i've seen don't mean ****.
Paul
