Anybody regret using Hals for a street car?
LS1Tech Sponsor
I've had my QA1's on all four corners for YEARS and haven't had a problem. I bet I've logged 20k miles on them and they're still fine
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
Restricted User
No issues out of mine either. single adj QA1 Star series in rear, and the R or is F series in front, (not new dbl adj) w/ QA1 Springs. over 15k miles and lots of track use.
They are great for street use, since they are adjustable you can tighten them up for the street and loosen them at the track. If too loose they suck on the street and the car bounces all over the road. We had ours on for 2 years and the worked great even with the drag springs on the front. One of the shocks did leak as stated above.
I only have about 10-12K on mine but still no signs of any problems yet. My street is horrible too, I have to crawl up it when I have the skinnies on the car to keep from bending one. "R" Series in the front and regular "F"s in the rear. Even if I do have to send them out to be rebuilt every other year they are still worth it.
So everybody is using the R series on the street? I was thinking about using QA1s drag coilover front system R series for my daily driver 68. They said that theyr not for the street and would do it. But everyone on here isnt having problems except for a few leaking after a while?
Thanks
Kyle
Thanks
Kyle
LS1Tech Co-Founder
Tom, if you run QA1's and stock front springs it's not bad. I would run the shocks at a middle setting to be like the factory 50/50 rate. If you run 'em too loose they will wear out.
