Drag Racing Tech
what more can i remove off the nose to loose weight?
Old 03-31-2005, 05:12 PM
mike c.'s Avatar
Default what more can i remove off the nose to loose weight?
i have a 01 ws6 m6. i have removed air system,air conditioner and front sway bar. anything else....?
Old 03-31-2005, 07:50 PM
B18B1LS1's Avatar
windshield washer fluid resevoir
Old 03-31-2005, 08:31 PM
SMOKIN01TA's Avatar
um where do i start
light weight hood, front bumper support, the bumper support brackets, sway bar brackets, cruise control, horn, wipers, lots of brackets and i can name alot more, depends on how far you wanna go.
Old 03-31-2005, 11:17 PM
roadtrip120's Avatar
K-member, tubular arms, skinny wheels. Head lights,motors, brackets
Old 04-01-2005, 12:16 AM
LS1TECH Sponsor
Magnus's Avatar
Bumper suppert and then you can sawzall off the frame that sticks out that they bolt on to..
Old 04-01-2005, 09:51 AM
bad2000ss's Avatar
Originally Posted by SMOKIN01TA
um where do i start
Fender Liners are about 8lbs. The big plastic undercarriage that bolts around the bottom perimeter of the front bumper cover is another 10lbs. A lightweight battery will only set you back about $75 and save you 25-30lbs (Hawker Odyssey Dry Cell Battery PC680).
Old 04-01-2005, 04:08 PM
mike c.'s Avatar
thanks. i'm looking for free stuff and it's a street car,i'll need the whipers.i spent $4000 bucks on my new head, cam,ect set up this year. the $$$ light mods will have to come next year. all else will likely go. where can i buy the lighter battery? will it start every time on a street car with stock stero and a under drive crank pulley?
Old 04-02-2005, 12:44 AM
chpmnsws6's Avatar
the hawker will do just fine
Old 04-02-2005, 02:32 AM
snake charmer's Avatar
http://www.gotbatteries.com/items.as...SL167/37L167S1
Here is a link to the battery. Best idea is to buy one of these and just use it when going to the track or racing. Though I have known people to use it everyday but some dont crank after a while.
Old 04-02-2005, 08:48 AM
mike c.'s Avatar
thanks.
Old 04-02-2005, 10:28 AM
bad2000ss's Avatar
I bought my battery from the same place. Easy transaction and shipped quick. The mount is a very simple piece of aluminum we bent. The Car is not a daily driver but is started 2-3 times per week for the last year and it cranks just like normal. I've been thinking about painting it black though, it sticks out like a sore thumb.
Old 04-02-2005, 04:36 PM
Larry's Avatar
Here's my battery: http://www.gotbatteries.com/Productp...ctNum=37L105S1
Here's how I mounted it:
I can go back to a factory style battery in about 10 minutes. I kept the same connecting bolts to battery. So far no problem starting the car.
Old 04-02-2005, 07:49 PM
PRAY HRD's Avatar
wow, i just recieved my pc925 dry cell Odyssey batt today from Jegs and paid $155-!!!!! and it's listed for $102 - $110 on gobatteries.com
Dave
Old 04-02-2005, 07:58 PM
PRAY HRD's Avatar
good news for me possibly and a big thanks if so to you guys for posting this. i just called Jegs and they are going to call that site on Monday and verify the price and return the difference to my CC.
thanks again,
Dave
Old 04-06-2005, 11:20 AM
mike c.'s Avatar
nice stuff. my car is a weekend only,so i will have a new battery comming. also...i thought of keeping my windshield fluid holder. i think i may run new lines to my rear tires,fill it with VHT and use it to spray down for added grip. this would be great for street racing
Old 04-06-2005, 11:24 AM
I ruin the end of films...
mongse's Avatar
Until the lines gunk up w/ VHT. Cut it w/ methanol if you want it to work more than once.
Not like I've ever used VHT on the street before though.
Old 04-08-2005, 04:56 AM
Nate_Taufer's Avatar
OMG!!! cant tell you the pain in the *** that caused me as well mongse. I can't recall having it work for me more than about 3 times hehehehe.
Nate
Old 04-12-2005, 10:14 PM
DONAIMIAN's Avatar
Move to houston, on the back roads that we street race on, we have prepped lanes, litterally.
Old 04-13-2005, 09:17 AM
jaymans99ss's Avatar
Put the battery in the trunck Its not hard to do and the ket is about 100$.
