Drag Racing Tech
What slicks to run with new combo?
Old 04-06-2005, 01:12 AM
SUX2BU's Avatar
Default What slicks to run with new combo?
Ok i used to have an iron 6.0 with stock heads, M6 , a nice cam and a wet 150 shot. Car has 4.10 rear with a spool. it was weighin in at 3555 with me in it and i would run 11.40's at 120 on motor and 10.60 at 130 on the hose.
NOW i'm going to be a stock internal 5.7 LS1, no more jug, same 4.10 rear with a spool, TH350 w/4800 8" converter and a trans brake. And race weight should be around 3150 with me in it.
Should i run 26" or 28"? would the 26" make it down the quarter?
Old 04-06-2005, 09:07 AM
gator's 99TA's Avatar
i would go with a 28" drag. awesome tire and no worrys about running out of gearing. running out of gearing has more to do with rpms through the traps or trap speeds.
Old 04-06-2005, 01:02 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
28's. Now, if it was me I would run 30x10.5x15's
Coach
Old 04-06-2005, 01:57 PM
V6 Bird's Avatar
Coach
Over kill Damn bracket guys!
Mike
Old 04-06-2005, 07:59 PM
SUX2BU's Avatar
i'm probably going to try 26's first. ther is mostly 1/8 tracks around here anyway. and last month i just sold my brand new 28's. if i can hook on 26's i'll take them down the 1/4 and see if i can make it.
Old 04-06-2005, 08:32 PM
A3Z28's Avatar
i have a set of 26" et streets with 4 passes on them, if you're interested pm me for some info.
Old 04-06-2005, 11:45 PM
SUX2BU's Avatar
Thanx but i'll more than likely go with some ET drags.
