Drag Racing Tech
Did you guys have to grind this much for Prostars? (pic)
Old 04-15-2005, 12:30 PM
GM Muscle's Avatar
Default Did you guys have to grind this much for Prostars? (pic)
Just finished grinding and it seems like an awful lot. I havn't taken the caliper off yet but I'm willing to bet it's as thin as an 1/8" in acouple of spots. The only reason I had to touch the top is becaseu I run stick on weights, I didn't take hardly any off the top but alot came off that corner. Look familiar to anyone? Car looks badass with the 15x10s and new M/Ts though.
Andrew
Old 04-15-2005, 12:34 PM
vette=lack of penis
Cursed1's Avatar
Andrew
LOOKS ABOUT RIGHT TO ME. NO SPACERS?
Old 04-15-2005, 01:42 PM
GM Muscle's Avatar
Yep, no spacers here.
Old 04-15-2005, 01:54 PM
v8maro's Avatar
Looks good, what size MT's did u go with?
Old 04-15-2005, 02:32 PM
BIGBOS's Avatar
Thats about right
Old 04-15-2005, 03:45 PM
chpmnsws6's Avatar
lotsa meat left still. you grind about 2x that for telstars
Old 04-15-2005, 04:01 PM
Motorboater
SilverGhost's Avatar
that ain't **** man, don't worry about it.
you should see mine, they look like a melted ice cube compared to yours. 15X10 prostars here with a baby 7/16 spacer cuz they were still hitting just a **** hair.
Old 04-15-2005, 04:05 PM
GM Muscle's Avatar
Damn, I took them off to paint them and I actually broke through in two spots in each caliper. It's at the ends of that big clip that goes from the piston across the top of the caliper. I just put alittle cold weld in the holes and called it a day.
I went with the 275/50/15s. They look so badass with the car sitting so low. I'll take some pics on Sunday, I have to stick some new axles and a few other goodies in the rear first.
Old 04-15-2005, 04:38 PM
DietCoke's Avatar
Looks right to me, I just did a set today
Old 04-15-2005, 07:42 PM
chpmnsws6's Avatar
breaking threw is also normal....... mine did that..... then i grinded another few MM's off them
Old 04-15-2005, 08:19 PM
PlowTown Missile's Avatar
Be glad you didn't get Rodlites. They're even worse
Old 04-15-2005, 11:02 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Looks right, I have 15x10 Pro Stars and no spacers on my car (see avatar).
Old 04-15-2005, 11:57 PM
Loudmouth LS1's Avatar
Looks about right to me, I have 15x10 draglites with no spacers, and mine are just about the same, maybe a little more grinded. I eventually gotta get around to takin the time to paint the one I didn't paint, gotta grind the rust off first though!
Old 04-16-2005, 12:34 AM
Transam427's Avatar
how are alumastars for grinding?
Old 04-16-2005, 12:59 AM
Little G's Avatar
I need to use spacers with my 15x8s, does that mean I just have to grind the brakes down some more?
Old 04-16-2005, 01:52 AM
PRAY HRD's Avatar
Andrew
looks about right man. those indentations are gone, so they either fit now or you're getting really close.
Dave
Old 04-16-2005, 07:55 AM
GM Muscle's Avatar
Yeah I used those indentations as a judge for the second one. The first one took me 3 days because people kept stopping over to shoot the ****, the second one probrably took less than 20 minutes.
Old 04-16-2005, 08:23 AM
Turo's Avatar
So this is what I have to look forward to . Is your car a daily driver? How does it handle with the prostars and hal's?
Old 04-16-2005, 08:32 AM
GM Muscle's Avatar
The car isn't my real daily driver but I drive it everyday in the summer just because I can't resist. I havn't even started it yet this year but most of last year I ran skinnies on the front, 17x9.5s in the rear, HALs (Rs in the front), Hypercoil lower springs, and no front sway bar. I though the car handled fine with the shocks set at 6-8 in the rear and I always run the fronts on 1. This year it will be alittle more tough to drive with the 233/239 and the power steering is going to be history too.
Old 04-16-2005, 11:56 AM
DopeFedZ's Avatar
Mine looked the same. I also broke through a spot on the caliper.
Quick Reply: Did you guys have to grind this much for Prostars? (pic)
