Drag Racing Tech
How much mph do you lose going from DR's to ET Streets?
Old 04-19-2005, 03:22 PM
DOUBT IT's Avatar
Default How much mph do you lose going from DR's to ET Streets?
Like the title says. I was trapping at 110-111 on street tires and Nittos, now with a ported TB and better launch, best I can pull is high 109's. What gives? Does a ET Street really grow that much at the far end of the track?
The DR's are 245/50/16 Nittos, the ET Streets are 26-10.50-16
Any input would be appreciated.
Old 04-19-2005, 05:23 PM
mike c.'s Avatar
it happens when you hook better. i was doing 119mph then went to slicks and was only getting 116-117ish mph. my 60's droped from 1.9 to 1.6's in the process. the tires will be an inch or so taller at the end.
Old 04-19-2005, 06:42 PM
tektrans's Avatar
They grow so they effectively remove some gearing on the top end. Will hurt mph but ET should improve with a better 60 ft, unless you were hooking with the Dr's. If you were already hooking then going to the ET streets could actually slow you down a bit but you'd be more consistent.
Old 04-19-2005, 07:28 PM
NastySSoo's Avatar
IMO about 1 mph
Paul
Old 04-20-2005, 12:10 AM
DOUBT IT's Avatar
Thanks for the replies guys. I was hooking *fairly* well on DR's, but you're right, the ET Streets make the car a lot more consistent. In fact, on my last 10 runs, the 60" has not been more than .11 difference.
