Drag Racing Tech
How Do I Adjust My Mcloed Adjustable Master Cylinder.
Old 04-20-2005, 07:18 PM
NX_CaGEdApE00's Avatar
Default How Do I Adjust My Mcloed Adjustable Master Cylinder.
I was just wondering how to adjust my mcloed adjustable master so i can set up the clutch pedal to where it releases higher. THANKS
DAVE
P.S. Where is it located at??? I bought the car with it already on.
Old 04-20-2005, 11:30 PM
wrencher
wrencher's Avatar
The adjusting rod is the linkage to the clutch pedal. You need to take play out of the pedal to bring the release point up. Sure the master is still good? I know my McLeod has been a pain. You need to llosen the lock nut on the rod & spin the rod out, so it lengthens the rod. This will take freeplay out & change the release point up away from the floor. Dont over adjust or it will keep the slave partially applied, & tear up stuff.....
You need a little freeplay in the pedal.
