cage is finally in
cage is finally in
just finished my 10 point s&w cage install. it is a mild steel cage.
took these just before i painted it.
unfortunatly i painted before relizing i need to have the window net installed........i ordered a wolfe kit, which is chromoly and has to be tigged.....
the halo was a lil wide, bent the ends in to meet the top of the hoop, and i had to put 2 bends in each of the door bars to clear around the seat and the arm rest of the door other than that the cage was fairly simple to install. you will need a tubing nothcer to finish the job. and you will need to notch the material behind the dash for the drivers side a post bar to fit properly.
good luck and have fun with it
