Putting in a harlan two step?????
What do I have to go throught the dash with the gray wire for the clutch switch or can I tap into a wire at the PCM if so what wire???????????????????????????????????????????
LS1TECH Sponsor
It's the blue connector, pin 32. Should be a gray wire. That's the clutch
input for the 99+ PCM's. Tap directly to that wire with the gray wire from the
2 step.
2 step.
