Removing bumper supports front and rear????!!!
Has anyone done it? Can you completely leave them off, or just cut off part?
Anyone know how much weight can be saved?
I just might end up doing this, even though i do realize its less safe on the streets.
I did it on my SRT-4 it probably saved 20lbs fr and rr.
Id still like to know if the bumpers will be securely fastened without the bumper supports there? As in do they actually serve as points for the bumper cover to bolt to?
Frt Fascia does rest on the foam in front, if you dont make some kind of support you will probably see the fascia sag a bit making a small gap at the fender and a gap under the headlight covers if its a bird. This is what happened to mine but I know some people have been luckier with theirs. I am adding a small aluminum brace this summer when I do my IC swap.
