Best Race Fuel ??
Best Race Fuel ??
What is the best race fuel C16 or C14 or C12 or or ... for N/A 13.5:1 or 14.0:1 compression ?
and if i want to spray 250hp which one is better ?
Thanks
Thanks
11 & 7 Second Clubs
Call your local VP rep for answers to these questions. Each fuel is designed for specific application.
Originally Posted by oOoLy
What is the best race fuel C16 or C14 or C12 or or ... for N/A 13.5:1 or 14.0:1 compression and if i want to spray 250hp which one is better ? Thanks
Thanks
Thanks
Originally Posted by 1fastWS6
I run Sunoco 110 in my 'bird. Its 13.5:1 N/A. I'm planning to spray a 200-250 shot and when I do will probably go to 116 oct. to be on the safe side.
So if i run C14 in the N/A i will on the safe side ? or that will be too much ?
LS1Tech Co-Founder
You should go to their website and read up, but C12 is ~110L. C14 is formulated for high compression N/A (like your combo). C16 is for FI, like my combo. Some folks use C16 for motor + nitrous and some use the C19? or 21?, the nitrous fuel they have.
So plan on C14 for all motor.
11 & 7 Second Clubs
If you are running the GM PCM, ignition, cats, etc., you must run unleaded gas. In which case, VP makes a 104 octane unleaded fuel, which would handle c/r of ~13:1.
VP's C12, 14, 16, 25, etc. are leaded fuels.
Thanks
Thanks
So the 104 octane unleaded fuel will be good for N/A 13:1 c/r . but how about it if i want to use some nitrose ?
11 & 7 Second Clubs
104 octane unleaded fuel will be good for nos.
