Tips or tricks to fitting dash after 10 point install????
Just got my car out of the chassis shop and I am ready to get the interior back together. Chassis guy did not fit the dash or trim it for the cage. It is a Wolfe 10 point with the front cross bar( I wish I had known it wasnt needed for < 8.50s) ANYWAY, Im looking for tips tricks to get the dash back in and looking right without ruining it. Anything ya got will be much appreciated.
BTW, the dash is basically empty minus the body harness which has been cut down considerably
TIA!!!
TIA!!!
I'm running the same cage and I didn't have any probs with the install it is pretty straightforward. I did have to notch the dash pad a bit with a Dremel. The hardest part in my application was getting the dashpad to go back in. The dashpad was a bit wide and I had to kind of bend it in order to get it between the bars that run along the side of the windshield.
Originally Posted by Torkman15
Just cut a little and test fit untill you like how is looks. Mine looks like my 10 point grew there. Good luck to ya, Tom
Andy
