Spring compress
Spring compress
Hi guys,
I have a question about the coils on a rear coil-over suspension. As you can see from the picture, the purches can be spun to compress the spring or decompress it. It's a 12'' spring compressed to about 10'' wrapped around a 17'' shock as is extended/12'' with no shaft showing. First of all, I think I went with the wrong demensions.... but on to my question.
My question is, what will moving the purches up or down effect when launching at a drap strip?
And if my vocabulary is wrong, I apoligize. I was assuming the "purches" were the bottom holders of the spring that can be spun to compress the spring even more or decompress it.
Any tips/thoughts/ or corrections to the way I'm looking at things would be appreciated.
Kyle
Kyle
Hmm I'm not sure on how its going to effect launching. But raising or lower the spring purches, as I see it, won't effect the launching of the truck neccesarily. It's just going to raise/lower ride height. The thing that compresses the spring is the weight of the truck not the purches.
Ahh, I see what you are saying. Actually, moving the purches down will drop ride height and the spring will stay at the same compressed height because that is how much weight it is holding up. Is that accurate?
Sorry, I was confused.
I think I've seen a thread or two on ride height vs. launch... I didn't know that was what I was really looking at.
Thanks.
Thanks.
Thanks.
Yep you got it right. Maybe someone else can help you now with the ride height vs. launch aspect of it all
LS1Tech Sponsor
which shocks do you have???? How much stroke do they have???
If you have a 5" stroke shock then you want 1 3/4 of shaft showing. On a 7" shock you would want around 2.5 to 2 3/4 inches of shaft. It looks to me in the pics you have either too long a spring or too stiff.
