Strange rear brake question
I want to go with light rear brakes so I can run regular welds in the rear without grinding (already have aerospace fronts). I know the aeorspace rears use a spacer and clamps the bearing on like stock. I was wondering if the strange setup used the 'normal' drag race brake rear setup where the caliper bracket slides over the axle without having to fool with the bearing or if the bearings have to be pressed off to install them like the aerospace?
Originally Posted by Hawkn01
KP, the caliper bracket has a slot so you can remove without pressing the bearing off the axle.
Yea, thats the way most drag brakes are, I'm sure I could trim the bracket for the aerospace to go over the axle depending how it holds the bearing in. Wonder why aerospace made it like that as opposed to everyone else's rears when the front is a pretty thin U shaped bracket.
I have the stange rear breaks and you cannont install or remove them without pressing the bearing on/off... maybe they changed the kit since i got it. got mine less than year ago.
