Drag Racing Tech
WTF is wrong with my car?
Old 06-29-2005, 09:04 PM
Retired Street Racer
Matt D's Avatar
Default WTF is wrong with my car?
alright guys, since my car is for drag racing only, i figured i would post here. my car is blowing the 15 amp eng ctrl fuse everytime it gets power to it. this is causing numerous SES codes, and the trans not to shift. it is electrical related, not trans. i think it is a wire shorting out, but where do i begin? any help would be greatly appreciated. thanks.
Old 06-30-2005, 09:54 AM
WhtLT1's Avatar
Best bet would to trace all the wires around the car and see if something is grounding out somewhere. That could just be a simple thing, but that's all I got
Old 06-30-2005, 10:03 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Did you try posting in the trans forum?
Old 06-30-2005, 10:34 AM
Matt D's Avatar
yeah i did john, but i got nothing
Old 07-01-2005, 12:11 PM
Matt D's Avatar
anyone?
Old 07-01-2005, 03:37 PM
Matt D's Avatar
hooked up a multimeter and it is picking up a half volt somewhere. unplugged the harness to the trans, and it is still blowing the eng ctrl fuse.
Old 07-01-2005, 06:00 PM
CamaroCain's Avatar
The evap vent solenoid, auto trans, and evap purge solenoid get power from this fuse.
I wouldn't bet that any of them are shorted, but to make sure just unplug all of them(looks like you already tried the trans) and see if it still blows the fuse.
Like said above i would bet that it is a shorted wire. But at least you know what wires to check, there are several connectors in-line to these items that would help narrow it down, but i cant remember which ones off the top of my head. I will see if i can look them up.
Old 07-01-2005, 07:10 PM
Matt D's Avatar
thanks, yeah we tried pulling the harness from the trans, and it still blows. we know it is a short, but finding it is gonna be the fun part.
Old 07-02-2005, 01:37 AM
WhtLT1's Avatar
Not excactly. Its' ALWAYS killing the fuse right? Just put a multimeter on the end of each wire and check resistance if u get a huge number that ones ur problem. If I'm thinking of this wrong please someone correct me
Old 07-05-2005, 03:53 PM
Matt D's Avatar
Cain, did you ever get around to looking that up?
Old 07-05-2005, 04:01 PM
jasontaws6's Avatar
Make sure the wiring harnes is not rubbing against your headers and grounding out. Happened to me before.
Old 07-05-2005, 06:05 PM
Matt D's Avatar
it's not, but thanks for your help.
Old 07-05-2005, 07:00 PM
CamaroCain's Avatar
1st one is connector C200B(terminal D2 is the wire) which is part of the IP harness behind kick panel below steering wheel. This one will be a pain in the butt, Its the big connector that all the power routes through from the ignition switch and multifunction switch. the power wire for the evap vent solenoid runs through this connector before going out the back pass through connector and going to the tank.
The other connector is c100(terminal G is the wire) it is one of the 3? good size connectors sitting on the passenger side fender with 10 terminals. The power goes from the fuse through c100 and then to a splice (s107 which will be wrapped up in the harness somewhere) and then to the auto trans, and the purge solenoid. All the wires you will be checking will be pink(there are a bunch through out the LS1 harness.)
Have you had the trans out?? its easy to pinch wires between trans and block. hook up voltmeter and check continuity between ground and fuse block which you will have since it keeps blowing fuse(one side will be grounded). Then unplug each item and see if it goes away(most likely not). then unplug each inline harness and see which one makes it go away. When it goes away, you should be able to narrow it down quite a bit. This should get you close.
Good Luck
Old 07-05-2005, 08:29 PM
Matt D's Avatar
thanks a lot man. i can't thank you enough. this is exactly what i needed. i owe you a beer the next time i am in the galveston/houston area, which is often.
Old 07-05-2005, 10:14 PM
Restricted User
CAT3's Avatar
What have you worked on recently, the days before fuse blowing?
Old 07-06-2005, 12:36 PM
Matt D's Avatar
nothing recently. it blew while i was on my way home from power tour.
Old 07-06-2005, 06:50 PM
CamaroCain's Avatar
No problem, too bad the car is not in this area i would help find the short...
