ET street keeps loosing air>>> - LS1TECH
Thread Tools Search this Thread
Old 07-02-2005, 07:05 AM   #1
matt94z's Avatar
Default ET street keeps loosing air>>>
Would it hurt if I put some Slime in the tire? Any other fixes? It will go from 30psi to around 6psi overnight. the other tire hold air fine.
matt94z is offline   Reply With Quote
Old 07-02-2005, 07:57 AM   #2
koolrayz's Avatar
take a spray bottle of soap (windex works fine) spray the tire and bead area. look for bubbles and find out where the air is leaking. if its in the bead then read the attached post i started. After using the method described i have not had to air them up again.
http://www.ls1tech.com/forums/showthread.php?t=337015
koolrayz is offline   Reply With Quote
Old 07-02-2005, 10:01 AM   #3
ss2000's Avatar
i coated the inside of mine with palmolive dish soap. they haven't leaked since i mounted them in febuary.
ss2000 is offline   Reply With Quote
Old 07-02-2005, 10:58 PM   #4
10 Second Moderator
Torkman15's Avatar
Quote:
Same here, Palmolive coating on the inside before mounting and 12 PSI for weeks. WORKS.
Torkman15 is offline   Reply With Quote
Old 07-03-2005, 09:49 AM   #5
koolrayz's Avatar
The dish soap keeps the air from leaking out the sidewalls which is a slow leak situation. most of the time the bead is the big problem IMHO
I always use the dish soap also. i think next time i will coat the inside with the slime. It would have to work better just for a little extra insurance
Old 07-03-2005, 01:24 PM   #6
matt94z's Avatar
I found my leak at the track last night. It is a small pin hole in the tire. Any fixes without tubes???
Tags
air, leak, put, slime, street, streets, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
