A4 410 Or 456 Gears
A4 410 Or 456 Gears
Anyone running the 456 gears in a 10 bolt. We changed from Et Streets 26 x 10.5 x 15 to the ET Drags 28 x 10.5 x 15 and lost about 2-3 tenths running the 1/8. The ET Drags are about 3 inches taller and 1 1/4 inch wider, that was a surprise. I was thinking about going with the 410 or 456 to make up the difference. We are running the stock 10 bolt with 373 Strange gears. The car is a 99 Formula built A4 420 rwhp N/A track only with a vig 3800 and yes we have around 125 passes with no problems out of the rear end. YET!!!!!!!!
1.50 to 1.60 60ft 7.2 at 94mph before the tire change.
Thanks
Alan
Thanks
Alan
9 Second Club NA
Anything above 3.73 is pushing it in a 10 bolt being that it gets weaker as the number gets numerically higher. If you had a 12 bolt, I would say 4.56 all the way. It seems to be the perfect gear for a 28" slick. You could try doing a 4.10 in a 10 bolt, but wouldnt suggest a 4.56. However, if you try it and break it and go with a 12 bolt, go with a 4.56. I have a 4.10 now using 26x10x15 ET Drags and I'll be upgrading to 4.56 with 29.5x10.5x15 ET Drag.
Retired Street Racer
i run 4.10 gears with a 25.7" tall tire. on motor i go through the traps right at 6100 rpms. it's so close i shift into 4th right at the traps. with your 28" tall tires, that would be just about perfect.
9 Second Club NA
Well that all depends on slippage, rev limiter, etc. There are other factors that need to be put into the equation. I have a PT4400 and I dont lock it up with a 4.10 gear on 26" Drags and I pass through the traps at 6800-6900, but then again, I have a 7200 rpm rev limiter and shift at 7000.
Originally Posted by Shon Herron
you could run 4.30s from Yukon Gear in the 10 bolt.
I think the 410s are going to be the gear I need until it explodes and we go with the 12 bolt or 9 inch.
Thanks for the reply
Alan
