Drag Racing Tech
Strange brake install question??
Old 07-18-2005, 02:17 AM
WOT
WOT's Avatar
Default Strange brake install question??
I am getting ready to do the install on my car this weekend and was wondering if anyone had any advice or knew of a good website with instructions. i have limited experience with brakes and was just looking for a little help. Was there something that you wish you knew or did differently when you installed yours? Thanks in advance guys.
Old 07-18-2005, 06:06 AM
So Slow's Avatar
Just remember that everything fits flush with the spindle..The Strange hub and the supplied brake mount has to fit together and flush up against the factory spindle for everything else to line up..
Also on my car I only had to remove the top mounting pad for the original caliper..I left the bottom one on but had to take a grinder to the face of it a little..Some people take both of them off..
Old 07-19-2005, 12:33 AM
WOT
WOT's Avatar
Thanks so slow. anyone else have any input?
Old 07-19-2005, 05:43 AM
BTL FED's Avatar
Thats about the only hard part to the install, like the guy above said make sure everything is flush, also dont forget the shims when bolting the caliper to the bracket to make sure the caliper is centered over the disk, my fronts didnt require any shims, but my backs did.
Old 07-20-2005, 07:22 AM
WOT
WOT's Avatar
shims??? what size is good to have on hand? i did get some spacers made for the rear (12 bolt) if that is what you are refering to.
Old 07-20-2005, 11:26 PM
So Slow's Avatar
The shims came with the brake kit at least they did with mine..They center the caliper on the brake disk..
Old 07-21-2005, 06:04 AM
BTL FED's Avatar
They came witht he brake kit, they are real thin washers
Old 07-21-2005, 07:45 AM
WOT
WOT's Avatar
thanks guys. i appreciate the help. i will post up if i have any problems with the install.
