Drag Racing Tech
Tire diameter of a MT ET drag 26x10.0-15 at top end?
Old 07-21-2005, 03:48 PM
V-10 Killer's Avatar
Default Tire diameter of a MT ET drag 26x10.0-15 at top end?
I'm going to try running a set of new ET drags next week and see how the car behaves. But I know the tire will get a little taller at high tire speeds. So what tire diameter should I put in there to keep things kosher with the PCM?
Thanks
Old 07-23-2005, 11:35 PM
2001-WS6's Avatar
Growth on those tires will not be worth messing around with in the PCM. Been there... ignored that.
Rick
Old 07-24-2005, 09:15 AM
Sweet. My stock tires are 26.2" so I don't figure it'll hurt any to just slap 'em on and go then.
Thanks
Old 07-24-2005, 11:20 AM
2001-WS6's Avatar
Yep, used to toss them in the back and put the jack on the floor and swap them on in the pits when I pulled into Stanton.
Rick
Old 07-25-2005, 01:58 PM
1fastWS6's Avatar
My 26x10's measured closer to 27" tall FWIW. They're considered a 'low growth' tire by M/T and won't affect anything anyway. You're brake light will likely come on if you drive around on them for a little while.
