Burnout and Rear Sliding out
Hello, probably a newbie question here but why does my car seem to always have the rear slide out to the right during a burn out at the track. I don't really use the brake in the begining, I just dump the cluth a bit and get the tires spinning, lightly apply the brakes and let off once the car "dusts off" the tires and starts to move forward. The rear is sliding out before I apply the brakes. I'm using stock F1s on a pretty much stock car. Any ideas?.
The tread on a street tire is hard, and does not benefit from a typical "burnout" where you heat tires up.
Originally Posted by ChevyGoldfinger
Many tire manufacturers and racers are of the opinion you need not do any "burnout" with stock tread. Most say the best bet is to go around the water box and if you want to "clean them off", just do a very short dry spin (3 or 4 foot black marks) then roll on up and stage.
