Drag Racing Tech
Who makes braces for wheel stands to save the oil pan?
Old 12-27-2005, 01:47 PM
BKHAWK1's Avatar
Default Who makes braces for wheel stands to save the oil pan?
Wolfe, Madman? I have seen them on here and couldn't find them on either site. any help would be appreciated.
Old 12-27-2005, 01:52 PM
Fireball's Avatar
I believe madman does.
best bet is to call him
Old 12-27-2005, 02:40 PM
BKHAWK1's Avatar
Yeah. i will do that after the 1st of the year when everyone gets back to work.
Is anyone running these? any pics?
Old 12-27-2005, 05:37 PM
rufretic's Avatar
I was looking for the madman ones, I read about them on here a while back but now I can't find them. I think they were just bolt on bars, nice, simple and easy to install. I'm going to be needing a set for spring time so I hope someone will post up about them. If I remember right he only made a set amount of them, so I don't know if he still has any or would still make them. I'd feel a lot better about getting lift off if I had a little protection for the landing lol.
Old 12-27-2005, 06:48 PM
BADFNZ's Avatar
He called them SYA bars or save your *** bars. If search was working you could look it up.
Old 12-27-2005, 09:37 PM
DopeFedZ's Avatar
Just give Madman a call and he will set you up.
Old 12-27-2005, 09:41 PM
rufretic's Avatar
I was just reading about them in an old post and someone said you need an aftermarket k-member for them to fit. Is that true?
Old 12-27-2005, 10:12 PM
LS1Tech Sponsor
Brady's Avatar
Yeah, they won't work with the stock K-member.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 12-28-2005, 07:10 AM
Blown408's Avatar
Wasn't the price of these SYA bars kind of high though? I could be wrong, but I was thinking they were about $400-$500?
Then again, it would be less expensive than replacing anything in the bottom of the engine.
Old 12-28-2005, 08:07 AM
LS1Tech Sponsor
MADMAN's Avatar
The bars run $100.00 and are disposable. You smash them instead of the headers and oilpans.
Attached Thumbnails Who makes braces for wheel stands to save the oil pan?-picture-070.jpg
__________________
www.madmanandcoracing.com
225-343-9029
Old 12-28-2005, 08:13 AM
BKHAWK1's Avatar
Madman is it mounted to the k-member with the rack-n-pinion mounting bolt?
Old 12-28-2005, 08:23 AM
Elite_Hot_Rod's Avatar
Yes, I have them on my car.
Old 12-28-2005, 09:42 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,097 Likes on 721 Posts
Look good, I need to get a set.
Old 12-28-2005, 09:51 AM
LS1Tech Sponsor
MADMAN's Avatar
You dont need them to DYNO your car PSJ.
__________________
225-343-9029
Old 12-28-2005, 10:03 AM
Slow Z28's Avatar
Low... Very low... but funny
Old 12-28-2005, 10:15 AM
Blown408's Avatar
Man, I was way off... I thought they were more expensive.
This is for two bars correct?
Old 12-28-2005, 10:16 AM
LS1Tech Sponsor
MADMAN's Avatar
Yes it comes as a pair.
__________________
225-343-9029
Old 12-28-2005, 11:37 AM
Race your car!
JL ws-6's Avatar
There's no way to make a set for the stock K member is there? I'd be intrested for a set this spring.... just in case. Not sure what's gonna happen when I hit the transbrake button off a 5000 converter....
Old 12-28-2005, 11:38 AM
BADFNZ's Avatar
The stock k-member would more than likely protect your oil pan on a hard nose down.
Old 12-28-2005, 11:49 AM
Race your car!
JL ws-6's Avatar
Understood.. but a set of bard to absorb the impact wouldn't hurt. I plan to swap the whole front end over to LW stuff... just don't wanna have to do it because I screw up and let off instead of pulling 2nd gear and trying to ride it out, should the front end come up in a big way.
R series shocks for the front are probably gonna happen as well before I get to the track.. will the set compression with a stock K be enough to not have to be concerned? Car made 403 rwhp cam only M6, now has a good set of ls6 heads on it, probably in the 430 to 450 rwhp range before the th400 goes in... after teh swap I'm guessing about 370 to the tires give or take. Maybe I'm not even making enough power to be concerned?
Quick Reply: Who makes braces for wheel stands to save the oil pan?
