15x10" Welds with 26x11.5" ET streets?
I have been noticing a trend in quicker street/race cars that run DOT tires and are limited to a certain width tire. They seem to run the widest rim they can get away with. Like some 275/60/15" ETstreet radials on a 10" rim. I have both 10" and 8" Welds for my T/A and have some 26x11.5" Et streets on the 8" and 325/50/15's ET street Radials on the 10's. Well I am trying to get the car in the 10's N/A and was thinking about swapping the 26"x11.5" Et streets onto my 10" rims to get a better contact patch. I would just leave the Dragradials unmounted until I was ready to put them back on. LMK What you guys think? Clint
1 Post
The 10 inch rim will give you a wider contact patch. The better way to hook (assuming you are having issues with traction) is to use a 28" for more sidewall, and then change the gears to get the max on the motor.
Yes, I agree with you guys. I am having some traction problems and do have a set 28" tires that I run on the car with n2o however they hurt my ET's on motor. So instead of swapping gears it's alot easier to swap tires and rims. I ran the car just a couple weekends ago and the best 60' was a 1.56 so I am going back to the track next week with the 15x10's and same 26x11.5 ET streets to see what it will do. I have also changed a few things so it won't be a fair comparison but as long as it's quicker oh well. Later Clint
Email me your suspension set up, you make alot more power than me but should be able to get the car to hook, if the track is close to being prepped.
We went to Shady Side a few weeks ago and I have never hooked there (in my other car) but with this M6 car we left at 6k and with the shocks on full loose (stock shocks on the rear) it hooked everytime.
I will add a pic to this b/c I think it is cool for a Bolt on car to do this!! This pic is from that day at shadyside.
The real trick to running Shadyside is to go when they are having their big shoot-outs. Otherwise it is hit or miss on track conditions. Let me know next time you are coming up. It is only fifteen minutes from me.
Take Care,
Daren
Originally Posted by GIZMO
Shon,
Take Care,
Daren
Take Care,
Daren
