Drag Racing Tech
Removing Heating&A/C from car need help
Old 12-29-2005, 01:09 PM
02WS6Bird's Avatar
Default Removing Heating&A/C from car need help
ok well as the title says i've removed all the junk from behind trhe dash which i would guess is the Vents, air ducts, Heater core, HVAC (what exactly is this) and all the A/C components. What i need to know is what are the three plug ins on the back of the intake manifold. The Map Sensor the brake booster and whats the other small one? It looked like it was connected to the a/c unit or soemthing of that nature. Is it needed? should it be plugged what do i do w/ it? thanks in advance
Adam
Old 12-29-2005, 01:13 PM
Shon Herron's Avatar
It probably is the vacuum line that was used to change the air flow, from feet all the way to defrost. that should be capped.
Old 12-29-2005, 01:21 PM
02WS6Bird's Avatar
thanks
anybody else, pics etc what do i do? The little line looks liekt eh ones that were on top of the HVAC system and everything there were like 4 of them? but only one plugged into the intake manifold
Old 12-29-2005, 01:24 PM
yep, that's it.
Old 12-29-2005, 09:24 PM
02WS6Bird's Avatar
thanks
can i get other feedback as well, or will that pretty much cover it? It's not needed if i pull the cooling/heating setups correct? Just plug it up and I'm good to go?
anything else in that area that needs special attention upon removal?
Old 12-29-2005, 09:44 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
don't forget your thongs behind the glovebox hhaa whats up adam, still riping it apart i see.
Old 12-30-2005, 12:46 AM
02WS6Bird's Avatar
Oh Snap, lol Yeah still doing the tear down ordered the cam get ready man should have it in the next week, valve springs same, then i just need pushrods, lifters the timing chain oil pump, , and if im lucky the underdrive pulley. Then theres just a couple gaskets then the PCV hose you got for me and that damned power steering pulley! lol
Javi, you have a dif. intake manifold what did you do for all the sensors in the back do you know what ehtey all are?
Old 12-30-2005, 01:00 AM
02WS6Bird's Avatar
Here you see the VERRRRY tiny wire im tlaking about or atleast what looks the same plugged in NEAR the PCM
Attached Thumbnails Removing Heating&A/C from car need help-wire1.jpg
Old 12-30-2005, 01:01 AM
02WS6Bird's Avatar
This all appears to be connected and i would liekt o know if its safe to get rid of it
Old 12-31-2005, 12:51 AM
Cheater's Avatar
thats way to much (gutting)
Old 12-31-2005, 03:16 AM
SUX2BU's Avatar
Yes it comes from the back of the manifold and tee's off one side goes to the A/C controls and the other side goes to a vacum canister bolted to the bottom of your front right frame. pull the canister and lines out and just cap the nipple on your intake.
Old 12-31-2005, 04:05 PM
adam if you need a hand just give me a call. the rear sensors were no problem
