I searched: Is the upper PHB needed?
LS1TECH Sponsor
Search resulted in a yes it is VS. a no you don't need it.
Is there a real answer to this or is it that subjective?
I havn't run one for a season or so and my PHB mounting points are fine, but my car only cuts 1.40s. Some of the hard hitting guys have to renforce the PHB mounting points because they bend.
Race your car!
Mine;s been off.. I'm not doing anything impressive at the track yet, but have put about 8K on the street with it off, no ill effects. I know nothing is bent either.. I took some measurments before I took it off, and have checked them once a eason since then, nothing has moved. If you are road racing the car.. then it's probably a good idea to leave it in.
The biggest reason I would personally keep it, even on a 1/4 mile car, is if you get pretty far out of shape on a pass. If you put the car sideways in the lane, there's a whole lot of stress on that single frame point, trying to push the subframe rails together/apart -- not to mention the stress on the single mount point. By keeping the upper bar in there, you're tying together the L and R subframes and distributing that load.
LS1Tech Co-Founder
Down the track, you don't need it. Trust me, I have fixed a number of suspension issues on my car and it currently leaves straight and tracks straight and that UPB does not do anything at the track.
But you will notice it gone when taking street corners... car feels less tight.
LS1TECH Sponsor
Well the new setup is not gonna be too street friendly. Drivability is defined as getting from the trailer, down the track and back to the trailer without stalling.
Motorboater
i have one or two up in my attic, one for sure. i might put it back on. i've had it off for 4 years with shitload of passes and plenty of street miles with no ill effects that i know of, but this has me thinking, i'm going to examine that area for any signs of stress before the spring and we'll see.
