roll cage on a vert
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Roll BAR is required by the NHRA for convertibles between 13.49 and 11.00. You'll need a minimum of 5-points including a driver door bar. Most install a 6-point with both driver and passenger side door bars, but driver bar is the only one needed. Swing-out bar is also allowed.
Go faster than 11.00 or 135 mph you'll need an 8-point or higher Roll CAGE. The specific requirements vary depending on how much faster you are going than 11.00.
EDIT: I mis-read the NHRA rule book, new info posted!
Derek
Derek
Originally Posted by Villain281H
Roll BAR is required by the NHRA for convertibles between 13.49 and 11.50. You'll need a minimum of 5-points including a driver door bar.
Go faster than 11.50 you'll need an 8-point or higher Roll CAGE. The specific requirements vary depending on how much faster you are going than 11.50.
Derek
Derek
Great I'm getting a 6point.
running times in my sig. I have heads, fast 90/NW90, gears waiting to be installed and bumping up the juice to150 which will put me well into the 10's
can someone show a picture of their 8point or higher setup in a vert.
NHRA and the track can lick my if think I'm putting more than a 6 point in.........love speed but love dropping the top cruising more
I've run deep into the 11's time after time with no bar at all. Just make sure your track is lax on the rules. I'm glad they hire total ******* retards nowadays, otherwise I'd be SOL.
I wouldn't chop up my car just to drive it where it spends about .00005% of it's life. But I personally hate rollbars.....some will toss one in even though they never go to the strip. To each their own.
7 Second Club
1 Post
Just my $.02
Derek
