Drag Racing Tech
Leave Fan on our off when making 1/4th?
Old 01-07-2006, 05:00 PM
LS1FIRE's Avatar
Default Leave Fan on our off when making 1/4th?
Should i leave my manul fan switch on our off when making my runs at the strip?
Old 01-07-2006, 05:46 PM
BADFNZ's Avatar
Off. You have enough air flowing through the radiator during a run and leaving it on is only putting an unneeded load on the alternator.
Old 01-07-2006, 05:56 PM
sleeperstyle's Avatar
i have always raced with my high fans on (i have the slp switch). don't think it would really make a difference but i like to keep my trans temps down and my cooler is mounted in front of the rad so the fans cool the trans tremendously.
Old 01-08-2006, 08:10 AM
TWS
TWS's Avatar
I always race with both of my fans running on my '94. Won't make any measureable diff during your pass, but I want them on during my drive back on the return road and my home-made switch is mounted in the engine compartment, not in the dash. My '02 has the SLP fan switch, so it's mounted in the dash and I usually do not have it on during the actual pass.
Old 01-08-2006, 11:45 AM
J 98ta's Avatar
I run the fans on until I finish the burnout, just before staging. Then after the finish line I turn them back on.
'J
Old 01-08-2006, 07:12 PM
rebersole2's Avatar
I have a two fan setup on my car. I run with one of my fans on all of the time. When I finish with the run, I turn on the second fan and leave it on until the car cools.
