Drag Racing Tech
mad man's rack (no pun)
Old 01-23-2006, 10:32 PM
7 Second Club
ty_ty13's Avatar
Default mad man's rack (no pun)
when using mad mans rack on a BMR k member do you have to get the pinto an manual rack setup or will it work with the standard power steering rack?
i ask because on the mad man rack it says it will work with stock Kmember.
Old 01-24-2006, 12:15 AM
GueSS Who's Avatar
His rack will work with any K-member that will except a stock rack. His is based off the stock setup. It will fit on a BMR. I have Madman rack with all BMR upfront. You do have to weld the tab to the K-member but other then that it is a bolt on peice that saves alot of weight.
Old 01-24-2006, 08:11 AM
7 Second Club
ty_ty13's Avatar
what would be the difference if you used a pinto kmember with his steering rack?
Old 01-24-2006, 08:23 AM
7 Second Club
ty_ty13's Avatar
and do you still get to keep the tilt function of the steering wheel?
Old 01-24-2006, 09:17 AM
LS1Tech Sponsor
MADMAN's Avatar
The steering column is the same either way. The pinto set up is similar to mine. The main difference is it doesnt have a steering linkage, or tierods, or bumpsteer kit. All this you will have to fab up. My kit comes with all the parts.
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-24-2006, 02:08 PM
7 Second Club
ty_ty13's Avatar
so i could still use my factory wheel? and yours is a complete bolt-on kit (with a little welding)?
sounds like a very nice piece.
Old 01-24-2006, 02:23 PM
LS1Tech Sponsor
MADMAN's Avatar
Everything in the car is factory.
My rack bolts on to the factory holes and requires one tab to be welded on.
__________________
225-343-9029
Old 01-24-2006, 02:38 PM
7 Second Club
ty_ty13's Avatar
sounds beautiful!
one more thing for me to do while the motor is out
Quick Reply: mad man's rack (no pun)
