Guys with stalled autos!!
I have a 3800 stall what should i footbrake the car to when running at the track just got the stall in a month ago now it time to go test it!!
depends on so many factors, including what kind of converter. i have been in yanks that look to be stalled up high. i have been in some vig con verters that loved to be flashed from idle! also, the bigger numeric gear, the less you will be able to load (stall) up the converter anyways.
Just test it out...It really depends on your suspension and car and everything...It took me a lot of tries to get my car to launch how I want it to...There really is no answer to this question IMO.
i brake torque up to 2200-2700 (depends on what mood im in) then flash it. every setup is different, but you'll probably get a more VIOLENT launch by flashing it from idle- just stomping on the gas pedal as fast/hard as you can. im on the stock rear so i pre-load it to the above rpms then flash from there.
3800 2.5str/ 2:73 gear.
probably depends on your setup also (cam, gear, track prep**)
