HELP! what slicks and drag wheels?
i know nothing about them :wall:
ok im gonna run a 15" wheel (have to grind i know)
the car is lowered
i assume i can only run a 26" tall tire. (true?)
what slicks do yall recomend?
i was looking at et streets
on jegs i see...
26'' x 10.5'' - 15''LT
and
26'' x 11.5'' - 15''LT
can i fit the 11.5 on a lowered car?
what size wheels? what offset?
what drag wheels are the lightest or most popular?
also
what about the fronts i want to run skinnys on drags, maybe a 3 or 4" rim? what offset? will i need spacers? what size tire?
any and all advice would be greatly appreciated......
the car is lowered
on jegs i see...
and
also
Originally Posted by KRS30
i have 26x11.5x15 et streets on my car with a pro kit on it right now with 15x10 7.5bs drag lites fits like a glove
can anyone else confirm this?
Originally Posted by SUX2BU
how much power you got? what do you expect to run in the 1/4? what gears you got? auto or M6? you want these just for the track?
i cant find a 15" x 10" prostar with 5 on 4.75" bolt pattern with a 7.5" BS... i can only find a 6.5" BS...
also can i use those wheels with stock 12mm studs? (no tech or NHRA rules at local hole in the wall track)
LME forged 347 (wiseco -2cc nitrous pistons, callies rods, stock crank)
MJ2 Cam(232/240 607/608 112)
Comp Cams Hardened Push Rods*Isky Racing Valve Springs*Isky Racing Titanium Retainers*Fastech Stage 2 4.8L Heads*2.055/1.60 Ferrera Valves*F.A.S.T. LSX 90mm Intake*F.A.S.T. 90mm Throttle Body*Custom Tuning by Sean Freese*85mm Lid & MAF*SLP Long Tube Headers*SLP Off-Road Y-Pipe*Dynomax Bullet Muffler*Rear O2 Sims*NOS 5177 Nitrous Kit*CAGS Delete*Moser 12 Bolt Rear End*33 Spline Axles*Eaton Posi Unit*Richmond 4.10 Gears*Polyurethane Sway Bar Mounts*EGR Delete*Taylor 10.4 mm Plug Wires*A.I.R. Delete*RAM Powergrip HD Clutch*LS6 Master Cylinder*LS6 Slave Cylinder*
next up NX dual shark 250 wet shot and (these) slicks...
Originally Posted by STANG KILLA SS 2
M6, yea definatly track only
927-96-510284 Pro Star 96-Series Wheel
Size: 15'' x 10''
Rear Spacing: 7-1/2''
Bolt Circle: 5 x 4-3/4''
$189.99
how heavy is your car?
with 26's at 6,800 you would cross the traps at 128mph
with 28's at 6,800 you would cross the traps at 138mph
Hell when i was a heavy (3,555 lbs) cam only M6 with a wet 150 i was crossing the traps at 128 i think.
BUT you might just be running 1/8 mile so i don't know.
JEGS!
Size: 15'' x 10''
$189.99
Size: 15'' x 10''
$189.99
dont know the exact weight but VERY heavy VERY..
only weight reduction is !rear speakers
everything else just adds wieght, (show car as well)
you are probably going to have to run a 28" tire. Lowered cars run them al the time you just have more clearencing to do.
With 26's your going to run out of gear.
all the cars at FASTECH with 28" slicks had there rear bumpers cut, im not willing to do that.....
what backspacing with a 28? 6.5 or 7.5?
i run 1/4 mile. what do you mean ill run out of gear? u mean ill have to shift to 5th?
hmm that would be perfect... are they better/worst/the same as the et streets?
just looked, jegs doent list that or anything close
Um is Jegs the only place you think carrys tires????
I found them 1st thing on Summit...... easy find........
Hoosier Quick Time Pro D.O.T. Tires
Tire, Quick Time Pro D.O.T, 27.0x11.5-15LT, Bias-Ply, DOT- Approved, Solid White Letters
$164.95
Pt # HOO-17510
I would go with a M/T ET Street Radial also..... 275/60/15 is a 28" tall tire..... but the whole lowering this messes you up....... i gave up on that..... went back to filling the wheel well with the tire instead of lowering the car to meet the tire.........................
