15x8 prostars, which size ET street?
i have 15x8 prostars on the rear. will a 26"x11.50" ET street fit? or do i have to use the 26"x10.50" on an 8" wide rim? If the 11.50" wide do fit on the rim, will it rub the inner fender or is there enough clearnce?
The 11.5's will fit just fine.. I know plenty of guys running the 11.5's on 15x8 Welds and Centerlines. It should not rub unless you have the wrong backspacing or are running lowering springs.
