Looking for Madmans alignment specs
Some reason search isn't working. I would like his drag racing alignment specs . I getting a alignment soon. Can some one help me out? Thanks
Restricted User
Luckily I seen this post a couple days ago... I just installed my PA Racing CM-Tubular K Member and A Arms. I didnt look at the settings, other than to get both tires toe in, since they both sat out badly. I mounted the tires and seen the fricken drivers tire is so far forward it rubs the inner wheel well...oops. But, I am getting the alignment done tuesday, so I searched for this thread and hopefully they (Midas) will meet my desires, as well, recenter the wheel in the fender opening. Thanks Madman for contributing.
Charlie
Charlie
Works for me..
Originally Posted by MADMAN
The specs apply to any drag car.
2. Repeat #1 w/ you in the car.
3. Have the tech jack the ft end up in 1" increments, and record/print each hgt setting.[You in the car]
4. Look at the different hgts, and choose the setting that is closest to the attitude of the car, when racing it.
We video'd the car, and looked at the attitude at speed...
We did this, as the car was "loose" after 130 mph.
We found that the ft end did not settle, even w/ the Moroso springs, and QA1's set loose.[Too much torque?? ]
Once we looked the alignment results, it became apparent why the car was loose... caster was going negative.
Once the ft end was "tuned", the car drove like it was on rails!!
Back to
